I know how to change an icon this way. Also that doesn't work for folders inside Nautilus, but for application launchers.
What I'm looking for is an equivalent to changing the icon for an application in the launcher, i. e. the Home folder, via
gedit ~/.local/share/applications/nautilus-home.desktop
That way you can set an icon type, which is helpful when you later want to change the icon set resp. theme or when you want the best resolution for each size of the icon.
So, I know how I can do this for applications in the launcher - but how can I realize this for icon folders in Nautilus? (In which file these settings are stored and editable with i. e. Gedit?)
For example, I try to change the folder icon for ~/.wine/drive_c. I want to use this Faenza icon (I use Faenza-theme, the icon is called folder-wine.png):
I want it to appear in best resolution: smaller as bookmark in Nautilus' sidebar, bigger as folder icon when I search Unity's dash. Using the scalable svg is not a solution, because it looks slightly different from the equivalent png.
