62
When I launch nautilus from terminal the following error is printed and nautilus doesn't open up.
(nautilus:25179): GLib-GIO-CRITICAL **: g_dbus_interface_skeleton_unexport: assertion 'interface_->priv->connections != NULL' failed
Could not register the application: Timeout was reached
(nautilus:25179): Gtk-CRITICAL **: gtk_icon_theme_get_for_screen: assertion 'GDK_IS_SCREEN (screen)' failed
(nautilus:25179): GLib-GObject-WARNING **: invalid (NULL) pointer instance
(nautilus:25179): GLib-GObject-CRITICAL **: g_signal_connect_object: assertion 'G_TYPE_CHECK_INSTANCE (instance)' failed
What could be the problem??
Byte Commander
  • 110,243
This answer by cortopy in ask.fedoraproject.org, worked for me.
I've been experiencing a similar problem today, only I couldn't open nautilus at all. So I'm wondering if this is due to some recent update clash.
This isn't a likely solution, but at least it allows me to carry on as normal.
First thing to try is sudo nautilus in a terminal. If it works, then it may mean that there is something wrong with active nautilus processess for your current user.
To be able to restart nautilus properly, do the following:
  1. See what nautilus processes are running :
    ps aux | grep nautilus
  2. Kill all nautilus processes you see :
    sudo kill PIDNUMBER
  3. Restart nautilus :
    nautilus -q
Tim
  • 33,500
tinto
  • 836
23
Please type in Terminal:
sudo killall nautilus && (nautilus &)
Done.
This has reported here: Nautilus does not start
Benny
  • 5,100
For me it was the following: I could open nautilus with
sudo nautilus
So then I killed all nautilus processes:
sudo kill <PID>
Tried:
nautilus -q
And got:
(nautilus:4918): GVFS-WARNING **: can't init metadata tree /home/user/.local/share/gvfs-metadata/home: open: Permission denied
So I checked permitions of each of these folders doing:
ls -la /home/user/ | grep .local
ls -la /home/user/.local/ | grep share
ls -la /home/user/.local/share/gvfs-metadata/ | grep home
And the folder home was owned by root so I did:
sudo chown -R user:user /home/user/.local/share/gvfs-metadata/home
