So after I installed 16.04 Ubuntu update, I tried to open my home folder, but it didn't work. I tried running nautilus in terminal and it thrown this:
user@user-desktop:~$ nautilus
(nautilus:13623): GLib-GIO-CRITICAL **:
g_dbus_interface_skeleton_unexport: assertion 'interface_->priv->connections != NULL' failed
Neizdevās reģistrēt lietotni: Iestājās noildze
(nautilus:13623): Gtk-CRITICAL **: gtk_icon_theme_get_for_screen: assertion 'GDK_IS_SCREEN (screen)' failed
(nautilus:13623): GLib-GObject-WARNING **: invalid (NULL) pointer instance
(nautilus:13623): GLib-GObject-CRITICAL **: g_signal_connect_object: assertion 'G_TYPE_CHECK_INSTANCE (instance)' failed
The Neizdevās reģistrēt lietotni: Iestājās noildze means Failed to register application: delay. I have no idea what's going on, but what I care more is how to solve this.
By the way, the nautilus opens fine when I run it through gksudo(gksudo nautilus).
I had the same symptoms as above.
Nautilus would not open as my own user. Nautilus would open fine using gksudo nautilus.
I opened a terminal to run as my own user, and got very similar error messages as above.
This link solved the problem for me:
Nautilus not opening up, showing GLib error
Here is the gist of the problem:
  • Some nautilus processes were still running that need to be killed.
The linked solution describes how to find the process ID's and kill them.
After that, I am fine - no need to reboot or anything.
TaoRich
  • 205
