When i open nautilus it works fine until i change the window to another application, then it crash.
I try to start nautilus from terminal to see what happens and this is the output:
arturo@toto:~$ nautilus
(nautilus:4110): GLib-GIO-CRITICAL **: g_dbus_interface_skeleton_unexport: assertion 'interface_->priv->connections != NULL' failed
(nautilus:4110): Gtk-CRITICAL **: gtk_icon_theme_get_for_screen: assertion 'GDK_IS_SCREEN (screen)' failed
(nautilus:4110): GLib-GObject-WARNING **: invalid (NULL) pointer instance
(nautilus:4110): GLib-GObject-CRITICAL **: g_signal_connect_object: assertion 'G_TYPE_CHECK_INSTANCE (instance)' failed
arturo@toto:~$ ^C
I try this solution from Nautilus not opening up, showing GLib error
arturo@toto:~$ ps aux | grep nautilus
arturo    1858  0.2  0.7 946456 59756 ?        Sl   10:20   0:06 nautilus -n
arturo    4176  0.0  0.0  16760  1012 pts/4    S+   11:12   0:00 grep --color=auto nautilus
arturo@toto:~$ sudo kill 1858
[sudo] password for arturo:
arturo@toto:~$ nautilus -q
Initializing nautilus-dropbox 2.10.0
** (nautilus:4181): CRITICAL **: Another desktop manager in use; desktop window won't be created
(nautilus:4181): Gtk-CRITICAL **: gtk_widget_destroy: assertion 'GTK_IS_WIDGET (widget)' failed
also try purge and reinstall and nautilus remains the same.
also tried this sudo nautilus error in 16.04
with no succes
What can i do to have nautilus working just fine, i mean without crushing?
