How to install OpenCV version 3.1 on Ubuntu 16.04 LTS to work with Python 3.5.1?
I tried this on a VM but obviously that is useful to do if you want to work with Python 2.
I found this.
OpenCV on wheels.
Unofficial OpenCV packages for Python.
Installation was painless for Ubuntu 16.04:
pip3 install opencv-python
Check the installation:
python3
Python 3.5.2 (default, Nov 17 2016, 17:05:23)
[GCC 5.4.0 20160609] on linux
Type "help", "copyright", "credits" or "license" for more information.
>>> import cv2
>>> cv2.__version__
'3.2.0'
python3-opencv can be installed from the Universe repository in Ubuntu 17.10 and later. Open the terminal and type:
sudo apt install python3-opencv
Upgrade your OS to 18.04 if you are using Ubuntu 14.04 or Ubuntu 16.04. If Ubuntu 16.04 is installed in WSL sudo do-release-upgrade will upgrade it to 18.04.
I have OpenCV version 3.1 on Ubuntu 16.04 LTS to work with Python 3.5.1. At the latest version it's fixed, try:
http://cyaninfinite.com/tutorials/installing-opencv-in-ubuntu-for-python-3/
But I didn't download dev python and OpenCV, I took directly from github:
EDIT:
Here are the instructions I tested successfully and mentioned in the link above:
sudo apt-get updateDownload the required packages to compile OpenCV:
sudo apt-get install build-essential cmake git libgtk2.0-dev pkg-config libavcodec-dev libavformat-dev libswscale-dev
sudo apt-get install python3.5-devpython3.5-config --includes The output should be similar to: -I/usr/include/python3.5m -I/usr/include/x86_64-linux-gnu/python3.5m. The first part of the output is the expected location & the second part shows the current location of the config file. To solve this problem, we’ll copy the file from the current location to the expected location: sudo cp /usr/include/x86_64-linux-gnu/python3.5m/pyconfig.h /usr/include/python3.5m/git clone https://github.com/Itseez/opencv.git. This will download OpenCV 3. Then rename the folder opencv to opencv-3Create a build directory, move to it and run:
cmake -D CMAKE_BUILD_TYPE=RELEASE -D CMAKE_INSTALL_PREFIX=/usr/local ../opencv-3
make and then sudo make install.The most simple and elegant way I found online is to install the library by running an installation script. Download the installation script install-opencv.sh, open your terminal and execute:
bash install-opencv.sh
Type your sudo password and you will have installed OpenCV. This operation may take a long time due to the packages to be installed and the compilation process.
The reference: https://milq.github.io/install-opencv-ubuntu-debian/
I am currently working with Google VM (ubuntu 14.04). Installing opencv on python3.4 version has been quite a task. I wanted opencv to be installed for python 3.4 but every time it was getting installed on 2.7 version.
I will share the steps I followed so as to help others on it.
Step 1 Follow all the steps as mentioned on openCv installation part till cmake. Link is given below:
https://docs.opencv.org/master/d7/d9f/tutorial_linux_install.html
Note: Install all the 3 packages mentioned at start. That optional one too..!! And don't forget to change the python version for which you are installing.
I did
sudo apt-get install python3-dev python3-numpy libtbb2 libtbb-dev libjpeg-dev libpng-dev libtiff-dev libjasper-dev libdc1394-22-dev
Follow step 2 for cmake.
Step 2 For installing opencv in specific version of python (ubuntu), you have to set the default (PYTHON_DEFAULT_EXECUTABLE) with the path to where your python is installed. You can find that out by using command whereis python3.4 (or, your version). Mine was in /usr/bin/python3.4
Instead of cmake mentioned on the page, use this,
cmake -D CMAKE_BUILD_TYPE=Release -D BUILD_NEW_PYTHON_SUPPORT=ON -D BUILD_opencv_python3=ON -D HAVE_opencv_python3=ON -D PYTHON_DEFAULT_EXECUTABLE=/usr/bin/python3.4 ..
Note: Don't forget to change your python version and path in PYTHON_DEFAULT_EXECUTABLE.
Step 3 Follow the remaining steps as mentioned in the link till sudo make install
Hope it helps.
Base guide: https://docs.opencv.org/master/d7/d9f/tutorial_linux_install.html
The following, tested on Ubuntu 18.04, installs OpenCV 4.1.0-dev and does not use python virtual environment. I haven't figured out how they work yet. I put the answer here so it has wider visibility.
[compiler] sudo apt-get install build-essential
[required] sudo apt-get install cmake git libgtk2.0-dev pkg-config libavcodec-dev libavformat-dev libswscale-dev
[optional] sudo apt-get install python-dev python-numpy libtbb2 libtbb-dev libjpeg-dev libpng-dev libtiff-dev libjasper-dev libdc1394-22-dev
How to install jasper: https://github.com/opencv/opencv/issues/8622#issuecomment-353761271
sudo add-apt-repository "deb http://security.ubuntu.com/ubuntu xenial-security main"
sudo apt update
sudo apt install libjasper1 libjasper-dev
The installation will include contrib modules.
cd ~/<my_working_directory>
git clone https://github.com/opencv/opencv.git
git clone https://github.com/opencv/opencv_contrib.git
(Git branch to 3.4 to install that version.)
If you mess up, just delete build folder and start over from here.
mkdir build
cd build
I use the following cmake flags:
cmake -DCMAKE_BUILD_TYPE=Release -DCMAKE_INSTALL_PREFIX=/usr/local -DOPENCV_EXTRA_MODULES_PATH=../../opencv_contrib/modules ..
Optional flags: (there are a lot of flags, see this blog post for some useful ones)
-DINSTALL_C_EXAMPLES=ON
-DINSTALL_PYTHON_EXAMPLES=ON
-DWITH_TBB=ON
-DWITH_V4L=ON
-DWITH_QT=ON
-DWITH_OPENGL=ON
-DWITH_NVCUVID=ON
-DWITH_CUDA=ON
-DWITH_OPENMP=ON
-DWITH_IPP=ON
-DWITH_OPENCL=ON
Ensure cmake finds your python version by checking its output for the following:
-- Python 2:
-- Interpreter: /usr/bin/python2.7 (ver 2.7.15)
-- Libraries: /usr/lib/x86_64-linux-gnu/libpython2.7.so (ver 2.7.15+)
-- numpy: /usr/lib/python2.7/dist-packages/numpy/core/include (ver 1.13.3)
-- install path: lib/python2.7/dist-packages/cv2/python-2.7
-- Python 3:
-- Interpreter: /usr/bin/python3 (ver 3.6.8)
-- Libraries: /usr/lib/x86_64-linux-gnu/libpython3.6m.so (ver 3.6.8)
-- numpy: /home/jx/.local/lib/python3.6/site-packages/numpy/core/include (ver 1.15.4)
-- install path: lib/python3.6/dist-packages/cv2/python-3.6
How to specify which python versions to use
Use make with the desired number of threads (ex. number of processors) then install.
make -j8
sudo make install
Things should now install to /usr/local
If all went well then you should be able to import cv2 in python.
import cv2
cv2.__version__
OpenCV can be installed using pip/pip3 and homebrew. I've tried installing it before using pip3 (Python 3.6.0), but i had problems with VideoCapture, which requires the ffmpeg package. cv2.VideoCapture('videofilename'). This is why I used homebrew for installing OpenCV. Open a Terminal with Ctrl + Alt + T and type the following commands:
brew install ffmpeg
brew install opencv3 --with-ffmpeg -v (Python 2.7)
brew install opencv3 --with-python3 --with-ffmpeg -v (Python 3.6)
