11
Just installed the UBUNTU 16.04 LTS. I just noticed that the software center is not working. I did installed the older version of it (sudo apt-get install software-center) but I want the new software center.
How can I install the new version of the software center?
Zanna
  • 72,312
Gabs
  • 1,125
  • 13
  • 18
Type the following in the terminal in order to update gnome-software, which should fix the problem:
sudo apt-get update && sudo apt-get install --only-upgrade gnome-software
You can also update using the graphical update manager, which will do the same thing.
(The version of gnome-software shipped with Ubuntu had a bug which meant that it sometimes wouldn't start, which was fixed in a update)
Jonas Czech
  • 4,047
I had the same issue. I looked on the dashboard and had two Ubuntu Software programs installed. Deleted the old one (Ubuntu Software Center). That fixed my problem.
Zanna
  • 72,312
john
This issue appeared on clean installation of 16.04, was fixed, and re-appeared. While it is difficult to replicate the issue and to analyze conditions, there was a fortunate remedy.
Using Synaptic Package Manager, go to Menu > Edit > Fix Broken Packages, mark identified packages for fix and upgrade, and let it apply.
Then restart the computer.
Zanna
  • 72,312
kovivox
  • 310
