I am using Ubuntu 11.10 and following instructions mentioned here to install Rabbit VCS.
I added the PPA properly, did a sudo apt-get update and ran
sudo apt-get install rabbitvcs-core rabbitvcs-nautilus rabbitvcs-thunar rabbitvcs-gedit rabbitvcs-cli
There were dependency issues and I googled a bit and found out that I need to install RabbitVCS only for nautilus as that is the default file manager for Ubuntu.
So I ran the install commands separately for rabbitvcs-core, rabbitvcs-gedit and rabbitvcs-cli.
Now my understanding is that those are installed properly.
However when I run the install command for rabbitvcs-nautilus, I still get a dependency issue.
ranhiru@ranhiru-HP-HDX16-NoteBook-PC:~$ sudo apt-get install rabbitvcs-nautilus
Reading package lists... Done
Building dependency tree
rabbitvcs-nautilus : Depends: nautilus (< 1:3.0~) but 1:3.2.1-0ubuntu2 is to be installed
Depends: python-nautilus (< 1.0~) but 1.0-0ubuntu2 is to be installed
How do I solve this?
