I'm trying to install RabbitVCS from its PPA (required because of a bug) but it won't:
# aptitude install rabbitvcs-nautilus
The following packages will be upgraded:
  rabbitvcs-nautilus{b}
1 packages upgraded, 0 newly installed, 0 to remove and 15 not upgraded.
Need to get 9,210 B of archives. After unpacking 4,096 B will be used.
  rabbitvcs-nautilus: Depends: nautilus (< 1:3.0~) but 1:3.2.1-0ubuntu3.1 is installed.
                      Depends: python-nautilus (< 1.0~) but 1.0-0ubuntu2 is installed.
The solution aptitude offers it to remove about 100 core packages, which is of course not right.
Is there some way I can tell aptitude to just go ahead, try if it works with a slightly newer nautilus than specified. Or is there something else wrong and should it normally just work?
(I installed 11.10 when it was at RC level or something, but that shouldn't matter, right?)
Also, just to be sure, I tried apt-get as well.
# apt-get install rabbitvcs-nautilus
Reading package lists... Done
Building dependency tree
 rabbitvcs-nautilus : Depends: nautilus (< 1:3.0~) but 1:3.2.1-0ubuntu3.1 is to be installed
                      Depends: python-nautilus (< 1.0~) but 1.0-0ubuntu2 is to be installed
But I haven't held any packages, at least not according to aptitude search ~ahold.
Ubuntu 11.10 uses Nautilus 3, so you need to install the rabbitvcs-nautilus3 package, not rabbitvcs-nautilus.
detly
  • 3,472
