49
Is there a standard or conventional keyboard shortcut for pasting the primary selection?
I'd like to select some text and go to another app to paste without trashing my clipboard contents. I'd rather keep my fingers on the keyboard than move to the mouse, find the pointer, position it where I want, and middle-click.
If there's nothing conventional, or if it's application-specific and unsupported by many, is there a workaround to get this working globally? (Or at least in more applications.)
10 Answers10
33
Sending virtual keypresses doesn't work for me (see comments), but that answer inspired me to look for similar solutions. Sending a "text" event with xvkbd ignores the current state of your physical keyboard:
sh -c 'xsel | xvkbd -xsendevent -file - 2>/dev/null'
xvkbd -text uses a few backslash sequences, so rather than dance with escaping, -file works. Add -delay 0 to enter the text without delay between the “keystrokes”. xvkbd also outputs some warning text about modifiers, but it appears to be irrelevant to this use (but I didn't want to see it in ~/.xsession-errors).
I bound this to a shortcut using System > Preferences > Keyboard Shortcuts.
Note that you need to have xsel and xvkbd packages installed:
sudo apt-get install xsel xvkbd
dessert
  • 40,956
11
I was looking for an answer for this very same question, and I found this answer that says that Shift+Insert is working to paste the primary selection. I works for me. Simpler.
Anne
  • 219
You can get this with the combined use of the programs xdotool (click to install) and xsel (click to install).
xdotool can simulate typing into a window; xsel outputs the contents of the PRIMARY selection (by default); the following shell one liner will do the trick:
 xdotool type `xsel`
To bind this to any key using the System->Preferences->Keyboard shortcuts menu item it is necessary to wrap it in a shell invocation:
 sh -c 'xdotool type --clearmodifiers -- "`xsel`"'
Typing in xdotool will not work with some programs; see the notes in the xdotool documentation.
Calling xdotool click --clearmodifiers 2 simulates clicking middle mouse button. This works much better than using xsel (at least for me). Altough you have to position your mouse before typing...
Another xdotool suggestion, working in Debian Jessie 8.7 (Jan 2017):
xdotool click --delay 0 --clearmodifiers 2
  • xdotool handles multi-byte strings (p.e. UTF-8), unlike xvkbd.
  • xdotool click simulates an actual click, so you don't have to click yourself to paste at mouse position, as you would have if you used xdotool type, or xvkbd.
The only problem is that --clearmodifiers will "press" back any modifier (Ctrl/Alt/Shift/Meta) you use after simulating the click. Even with --delay 0 (instead of 12ms), the command takes a little to execute. If you release the keys before it ends, your modifiers will be "pressed" again, and stuck there until you press and release the actual key once more.
So with this you have to be a bit "slow" (50ms?) to release your modifiers, if you're using any.
You can test this by setting up your keyboard shortcut, using it into a text editor, and then pressing a key (like a, or an arrow). The letter should appear in lowercase. If something else happens, you are too fast and a modifier is stuck (p.e. Shift if it's in caps, Ctrl if you selected all text, Alt if you opened a menu). Press and release your modifiers again to reset them.
If you're too fast, you can use ilkerk's suggestion:
sh -c 'sleep 0.3 && xdotool type --clearmodifiers --delay 0  "`xsel`"'
Then you have to release them in less than 300ms, and wait half a second for the text to appear.
Also, using xdotool type means you insert the text as if you where typing, at the text cursor position, and not the mouse pointer. You can change it to click if you prefer the usual middle-click behaviour.
(made this post so newcomers don't have to piece the puzzle pieces spread in the comments again)
Chema
  • 166
I had problems with the solutions that simulate pasting the PRIMARY selection, so instead I added a shortcut that copies the PRIMARY selection to the CLIPBOARD. After using my shortcut I paste the CLIPBOARD in the usual way, with Ctrl+V, Ctrl+Shift+V, or Shift+Insert, depending on the application.
The command to copy the PRIMARY selection to the CLIPBOARD is
sh -c 'xsel --output --primary | xsel --input --cliboard'
which I bind to Ctrl+Insert (arbitrary choice) in the Gnome shortcut settings under System Settings -> Devices -> Keyboard
Summary of problems with other solutions: I tried the xsel | xvkbd ... and xsel | xdotool ... solutions, but found they didn't work very well because they simulate typing the PRIMARY selection character by character, which is not the same as pasting it with middle click. Problems include: there's a long delay while a large selection gets inserted one character at a time; if you want to undo the "paste", you have to undo it character by character, which is slow; if you're using "dead keys" then everything gets messed up, e.g. "pasting" "e produces ë; the xvkdb doesn't handle unicode characters correctly.
Warning: This solution overwrites the existing CLIPBOARD contents, but the OP asked for solutions that preserve the existing CLIPBOARD contents.
ntc2
  • 700
I had the same issue and internet search didn't help me much. The problem simulating click 2 is annoying as OP mentioned.
The problem with the above proposed xdotool and xsel is when xdotool starts "typing" you are still pressing another key. That does not always result with any output. For example if you bind it to "insert" key then xdotool is sending keys while your finger is pressing "insert" key which causes nothing.
Below is a workaround, to bind it to a key press :
it is not perfect but working. now you have 0.3 seconds to finish your selection of key press (and key up).
ilkerk
You can also use xclip
Copy the content of primary to clipboard using the following command:
sh -c 'xclip -o -selection primary | xclip -selection clipboard'
You can bind this command to any keyboard shortcut of your preference. If you are using Gnome desktop environment you can do it by going to Settings > Keyboard Shortcuts or search for keyboard shortcuts in case of other DE.
Now, you can paste the content in the usual way by Ctrl-v or Ctrl-Shift-v.
HOWEVER This will overwrite the previous content of your clipboard!
In KDE on Debian Bullseye the default key combo seems to be Ctrl+Shift+Insert.
None of the above answers worked for me. There were two categories of problems:
  1. Not all programs respect the default DE shortcut to paste (e.g. Shift-Insert does not work in firefox).
  2. Emulating paste with xdotool or similar is not the same as paste. In particular, bracketed paste does not work, keybindings are processed instead of being bypassed (e.g. Tab), and it takes some amount of time to send each keypress. Additionally, xvkbd does not handle tabs correctly (it turns them into the letter I) and xdotool would freeze my desktop.
Instead, I wrote a small script that switches Primary and Clipboard temporary then does a normal XF86Paste that almost all programs respect.
#!/bin/sh
data=$(xsel -o --primary)
if [ "$data" ]; then
    old=$(xsel -o --clipboard)
    echo "$data" | xsel -i --clipboard
    # --window is necessary; otherwise firefox ignores the paste because the window isn't focused.
    xdotool key --window $(xdotool getactivewindow) XF86Paste
    sleep .1  # give firefox time to handle the event
    echo "$old" | xsel -i --clipboard
fi 2>&1 | tee /dev/stderr | logger -t paste
Then I bound that script to Insert in gnome-settings.
jyn
  • 101
