All solutions listed here for removing MySQL fails:
Uninstall MySQL from Ubuntu 16.04
and
Removing MariaDB Installs MySQL and vice-versa
These are my errors:
$ sudo apt-get purge mysql*
$ sudo apt-get autoremove
$ sudo apt-get autoclean
$ sudo apt-get dist-upgrade
$ sudo apt-get install mysql
$ apt-get autoremove
Reading package lists... Done
Building dependency tree
The following packages will be REMOVED:
  mysql-server-core-5.7
0 upgraded, 0 newly installed, 1 to remove and 131 not upgraded.
2 not fully installed or removed.
After this operation, 46.2 MB disk space will be freed.
Do you want to continue? [Y/n] y
(Reading database ... 287191 files and directories currently installed.)
Removing mysql-server-core-5.7 (5.7.22-0ubuntu0.16.04.1) ...
Processing triggers for man-db (2.7.5-1) ...
Setting up mysql-common (5.7.22-0ubuntu0.16.04.1) ...
update-alternatives: error: alternative path /etc/mysql/my.cnf.fallback doesn't exist
dpkg: error processing package mysql-common (--configure):
 subprocess installed post-installation script returned error exit status 2
dpkg: dependency problems prevent configuration of mysql-client-5.7:
 mysql-client-5.7 depends on mysql-common (>= 5.5); however:
  Package mysql-common is not configured yet.
dpkg: error processing package mysql-client-5.7 (--configure):
 dependency problems - leaving unconfigured
No apport report written because the error message indicates its a followup error from a previous failure.
 mysql-common
 mysql-client-5.7
Thomas Ward
  • 78,878
It looks like there is an error while configuring mysql-common, and that causes a dependency problem that results in mysql-client-5.7 failing to be removed.
The configuration error is error: alternative path /etc/mysql/my.cnf.fallback doesn't exist, so naturally i'd try to create that path by running sudo touch /etc/mysql/my.cnf.fallback
After that running sudo dpkg-reconfigure mysql-common will reveal if the error is resolved, if it is, you can likely remove mysql now using sudo apt-get purge mysql*
If this did not help, please provide the output/errors of these commands so that me and others can determine the problem further.
x13
  • 201
Solved:
There were two architecture libraries on my system for mysql.
libmysqlclient20:amd64 libmysqlclient20:i386
I removed the i386 and all is solved.
