I have a script named 999_thaw_flash.sh in my /etc/pm/sleep.d
The script follows like this :-
export DISPLAY=:0
#!/bin/bash
case "{$1}" in
    resume|thaw)
lynx --dump link1 >> file1
lynx --dump link2 >> file1
lynx --dump link3 >> file1
grep "magnet:?xt=urn:btih:" file1 > file2
sed -i 's/^......//' file2
awk '/org%3A1337%2Fannounce/{print;print "";next}1' file2 >> file3
lines=$(wc -l < file3)
echo "no. of line $lines"
    if grep silicon+valley+s03e03+720p+hdtv+x265+hevc+ file3;
        then
            lineno=$(grep -n silicon+valley+s03e03+720p+hdtv+x265+hevc+ file3 | cut -d : -f 1)
            echo "current line no :-" $lineno
            link=$(head -n $lineno file3 | tail -1)
            echo $link
                notify-send -i /home/hasan/Desktop/flash/Flash.ico 'Flash is Running' 'Getting silicon valley episode 3'
                transmission-remote -a $link
                echo $link >> flush
                echo "\n\n" >> flush
    fi
    if grep silicon+valley+s03e05+720p+hdtv+x265+hevc+ file3;
        then
            lineno=$(grep -n silicon+valley+s03e05+720p+hdtv+x265+hevc+ file3 | cut -d : -f 1)
            echo $link
                notify-send -i /home/hasan/Desktop/flash/Flash.ico 'Flash is Running' 'Getting silicon valley episode 5'
                echo $link >> flush
    fi
    if grep silicon+valley+s03e06+720p+hdtv+x265+hevc+ file3;
        then
            lineno=$(grep -n silicon+valley+s03e06+720p+hdtv+x265+hevc+ file3 | cut -d : -f 1)
            echo $link
            notify-send -i /home/hasan/Desktop/flash/Flash.ico 'Flash is Running' 'Getting silicon valley episode 6'
            echo episode 6 of silicon valley online
                echo $link >> flush
    fi
    if grep silicon+valley+s03e07+720p+hdtv+x265+hevc+ file3;
        then
            lineno=$(grep -n silicon+valley+s03e07+720p+hdtv+x265+hevc+ file3 | cut -d : -f 1)
            echo $link
            notify-send -i /home/hasan/Desktop/flash/Flash.ico 'Flash is Running' 'Getting silicon valley episode 7'
            echo episode 7 of silicon valley online
                echo $link >> flush
    fi
    if grep silicon+valley+s03e08+720p+hdtv+x265+hevc+ file3;
        then
            lineno=$(grep -n silicon+valley+s03e08+720p+hdtv+x265+hevc+ file3 | cut -d : -f 1)
            echo $link
            notify-send -i /home/hasan/Desktop/flash/Flash.ico 'Flash is Running' 'Getting silicon valley episode 8'
            echo episode 8 of silicon valley online
                echo $link >> flush
    fi
    if grep silicon+valley+s03e09+720p+hdtv+x265+hevc+ file3;
        then
            lineno=$(grep -n silicon+valley+s03e09+720p+hdtv+x265+hevc+ file3 | cut -d : -f 1)
            echo $
            notify-send -i /home/hasan/Desktop/flash/Flash.ico 'Flash is Running' 'Getting silicon valley episode 9'
            echo episode 9 of silicon valley online
                echo $link >> flush
    fi
    if grep silicon+valley+s03e10+720p+hdtv+x265+hevc+ file3;
        then
            lineno=$(grep -n silicon+valley+s03e10+720p+hdtv+x265+hevc+ file3 | cut -d : -f 1)
            echo $link
            notify-send -i /home/hasan/Desktop/flash/Flash.ico 'Flash is Running' 'Getting silicon valley episode 10'
            echo episode 10 of silicon valley online
                echo $link >> flush
    fi
esac
I hope that syntax is correct and the placement of script is in correct folder.
The script does not execute on system resume.
Where am I going wrong ?
I have tried :- Run Script on Wakeup?
how to execute a command after resume from suspend?
How to run a script after the system resumes from hibernate (suspent-to-disk)?
How to run a script when suspending/resuming? - Sony VAIO Ubuntu 12.04
https://unix.stackexchange.com/questions/37892/run-a-script-after-lid-is-opened
https://superuser.com/questions/733333/how-do-i-run-commands-on-suspend-return-from-suspend
But none seem to help me.
P.S. The script runs fine on terminal.
The logs :-
May 22 20:39:16 user-550p5c-550p7c systemd-sleep[19426]: /lib/systemd/system-sleep/flush failed with error code 1.
May 22 20:39:16 user-550p5c-550p7c systemd-sleep[19426]: /lib/systemd/system-sleep/Flash.ico failed with error code 1.
May 22 20:39:16 user-550p5c-550p7c systemd-sleep[19426]: /lib/systemd/system-sleep/file3 failed with error code 1.
May 22 20:39:16 user-550p5c-550p7c systemd-sleep[19424]: Failed to connect to non-global ctrl_ifname: (nil)  error: No such file or directory
May 22 20:39:16 user-550p5c-550p7c systemd-sleep[19424]: Suspending system...
May 22 20:39:23 user-550p5c-550p7c systemd-sleep[19424]: System resumed.
May 22 20:39:23 user-550p5c-550p7c systemd-sleep[19424]: Failed to connect to non-global ctrl_ifname: (nil)  error: No such file or directory
May 22 20:39:23 user-550p5c-550p7c systemd-sleep[19459]: /lib/systemd/system-sleep/wpasupplicant failed with error code 255.
May 22 20:39:23 user-550p5c-550p7c systemd-sleep[19459]: /lib/systemd/system-sleep/Flash.ico failed with error code 1.
May 22 20:39:23 user-550p5c-550p7c systemd-sleep[19459]: /lib/systemd/system-sleep/file3 failed with error code 1.
May 22 20:39:23 user-550p5c-550p7c systemd-sleep[19459]: /lib/systemd/system-sleep/file1 failed with error code 1.
May 22 20:39:23 user-550p5c-550p7c systemd-sleep[19459]: /lib/systemd/system-sleep/file2 failed with error code 1.
May 22 20:39:23 user-550p5c-550p7c systemd-sleep[19459]: /lib/systemd/system-sleep/999_thaw_flash.sh failed with error code 1.
May 22 20:39:23 user-550p5c-550p7c systemd-sleep[19459]: /lib/systemd/system-sleep/flush failed with error code 1.
May 22 20:39:25 user-550p5c-550p7c systemd-sleep[19424]: /dev/sda:
May 22 20:39:25 user-550p5c-550p7c systemd-sleep[19424]:  setting Advanced Power Management level to 0xfe (254)
May 22 20:39:25 user-550p5c-550p7c systemd-sleep[19424]:  APM_level        = 254
May 22 20:39:30 user-550p5c-550p7c systemd-sleep[19424]: Looking up kat.cr
May 22 20:39:30 user-550p5c-550p7c systemd-sleep[19424]: Unable to locate remote host kat.cr.
May 22 20:39:30 user-550p5c-550p7c systemd-sleep[19424]: Alert!: Unable to connect to remote host.
May 22 20:39:30 user-550p5c-550p7c systemd-sleep[19424]: lynx: Can't access startfile https://kat.cr/usearch/the%20flash/
May 22 20:39:30 user-550p5c-550p7c systemd-sleep[19424]: lynx: Can't access startfile https://kat.cr/usearch/gotham/
May 22 20:39:30 user-550p5c-550p7c systemd-sleep[19424]: lynx: Can't access startfile https://kat.cr/usearch/silicon%20valley/
May 22 20:39:30 user-550p5c-550p7c systemd-sleep[19424]: no. of line 0
penta
  • 354
  • 15
Adding this answer for anyone who still needs a solution for newer versions. I see this has been viewed many times.
I had to use a sleep/wake script to manually unmount/mount some network share folders that would hang otherwise on resume. I had a lot of trouble with setting this up, and discovered you need the "PATH=/sbin:/usr/sbin:/bin:/usr/bin" line to execute any terminal commands. You can use a basic script template like this for an example:
#!/bin/sh
PATH=/sbin:/usr/sbin:/bin:/usr/bin #required to execute terminal commands
case "$1" in pre) #sleep #script for executing with hibernation ;; post) #resume #script here for resuming ;; esac
Make sure the script is executable by typing "chmod +x /path/to/script/" in terminal. Make sure root is the owner with "sudo chown root:root /path/to/script/".
Hope this helps. Running on Ubuntu 20.04 and Linux Mint 20.2.
Since systemd the proper location for this is /lib/systemd/system-sleep. Make there a file eg. 999_thaw_flash and paste like this :
#!/bin/sh
case $1/$2 in
    post/suspend)
        your_srcipt_here ....
esac
EdiD
  • 4,617
  • 27
  • 41
