I have configured powernap to hibernate (i.e., suspend-to-disk) the machine if idle. In order to save additional power, I have configured my non-root, data disks to spin-down using the hdparm command. Unfortunately, this setting gets lost after resuming from hibernate.
I'd like to run these hdparm command right after the system has resumed. How/Where to install them?
You can do this by creating a script in /etc/pm/sleep.d
sudo nano /etc/pm/sleep.d/99_hdparm_thaw
Use this as your base:
#!/bin/sh
PATH=/sbin:/usr/sbin:/bin:/usr/bin
case "${1}" in
        hibernate)
                # this is where you put something you want to run before hibernating
        resume|thaw)
                # this is where you put something you want to run on resume/thaw
esac
You will then need to make sure it is executable:
sudo chmod +x /etc/pm/sleep.d/99_hdparm_thaw
There are other scripts in that directory, which is where I came up with the base. You may be able to use those for ideas.
Also, those scripts are run in alphabetical order. This is why I chose to name it 99_hdparm_thaw, so it will be the last run script.
reverendj1
  • 16,403
