12
According to this blog post I should be able to install the .deb version of the Unity Editor for Ubuntu. I have the recommended system requirements. But when I try to install the .deb file using the sudo dpkg -i mydebfile.deb I get the following errors:
Selecting previously unselected package unity-editor.
(Reading database ... 175283 files and directories currently installed.)
Preparing to unpack unity-editor-5.3.4f1 20160503_amd64.deb ...
Unpacking unity-editor (5.3.4f1) ...
dpkg: dependency problems prevent configuration of unity-editor:
 unity-editor depends on lib32gcc1 (>= 1:4.1.1); however:
  Package lib32gcc1 is not installed.
 unity-editor depends on lib32stdc++6 (>= 4.6); however:
  Package lib32stdc++6 is not installed.
 unity-editor depends on libc6-i386 (>= 2.15); however:
  Package libc6-i386 is not installed.
 unity-editor depends on libpq5; however:
  Package libpq5 is not installed.
 unity-editor depends on npm; however:
  Package npm is not installed.
dpkg: error processing package unity-editor (--install):
 dependency problems - leaving unconfigured
Processing triggers for gnome-menus (3.13.3-6ubuntu3) ...
Processing triggers for desktop-file-utils (0.22-1ubuntu5) ...
Processing triggers for bamfdaemon (0.5.3~bzr0+16.04.20160415-0ubuntu1) ...
Rebuilding /usr/share/applications/bamf-2.index...
Processing triggers for mime-support (3.59ubuntu1) ...
Processing triggers for hicolor-icon-theme (0.15-0ubuntu1) ...
 unity-editor
Has anybody successfully installed the Unity3d on Ubuntu 16.04 yet? Please help if you can.
EDIT: I've been asked if the question How do I install a .deb file via the command line? has solved my problem. The answer is: No, it hasn't. The answers in that question might help one learn how to fix broken dependencies using sudo apt-get -f install but that didn't solve my problem. I had to install each of the missing packages one by one (see comments below). So, I think people coming here for the same problem won't be able to know that they have to install the packages by hand if the question is marked as a duplicate.
Eisenheim
  • 449
  • 15
5 Answers5
Download
Unity is providing official support for Ubuntu
You can always get the latest releases of Unity3D:
scroll down the page for the latest release.
Install
Benny
  • 5,100
The dpkg -i command does not resolve dependencies and pull them from apt repositories. You need to install the package using the Ubuntu Software application, or you will need to apt-get install the listed dependencies by hand in a terminal, so that they will be installed and the dependencies for the unity-editor.deb file satisfied.
dobey
  • 41,650
Use gdebi! install this gdebi on Ubuntu software, and open file manaager, go to Download, and open terminal on Download. and run:
1.gdebi [.deb file you downloaded.deb(full name)] and wait...
  1. type y when you see [y/n].
  2. try to open Unity editor!
But there is one error I found: If you login, it always shows 'Service not available, please try again later.' Don't try to wait. it ALWAYS shows me.
The answers on this page are now all slightly out of date. Unity are no longer providing a .deb file. It took me a minute, but go to this thread:
https://forum.unity.com/threads/unity-on-linux-release-notes-and-known-issues.350256/
And navigate to the last page. Click on the link in the very last post (as instructed) and download the executable. After downloading you will need to add execution rights, either do this via the GUI (right click, go to permissions, and check "Allow executing file as program") or from your command line simply run
chmod +x unity-setup-filename
Now you can open the new graphical assisted installer!
GrayedFox
  • 191
To summarize this post
INSTALL UNITY3D IN UBUNTU 18.04
Find the latest Unity3D on Linux from HERE
sudo apt install -y libgconf-*
wget https://beta.unity3d.com/download/<checksum>/UnitySetup-YYYY.X.ZZZ
chmod +x UnitySetup-YYYY.X.ZZZ
./UnitySetup-YYYY.X.ZZZ
ln -s Unity3D-YYYY.X.ZZZ/Editor/Unity /usr/bin/unity3d
