So, I tried to install the KDE Desktop in Ubuntu, but it failed (I couldn't grab output for here). Now whenever I try to use apt-get , it says that it fails, and to use sudo apt-get -f install .
When I try to do that, it does this:
Reading package lists... Done Building dependency tree Reading state information... Done Correcting dependencies... Done The following additional packages will be installed: kde-config-telepathy-accounts The following NEW packages will be installed: kde-config-telepathy-accounts 0 upgraded, 1 newly installed, 0 to remove and 0 not upgraded. 679 not fully installed or removed. Need to get 0 B/137 kB of archives. After this operation, 825 kB of additional disk space will be used. Do you want to continue? [Y/n] y (Reading database ... 283445 files and directories currently installed.) Preparing to unpack .../kde-config-telepathy-accounts_4%3a15.12.3-0ubuntu1_amd64.deb ... Unpacking kde-config-telepathy-accounts (4:15.12.3-0ubuntu1) ... dpkg: error processing archive /var/cache/apt/archives/kde-config-telepathy-accounts_4%3a15.12.3-0ubuntu1_amd64.deb (--unpack): trying to overwrite '/usr/share/accounts/services/google-im.service', which is also in package account-plugin-google 0.12+16.04.20160126-0ubuntu1 Processing triggers for libc-bin (2.23-0ubuntu3) ... Errors were encountered while processing: /var/cache/apt/archives/kde-config-telepathy-accounts_4%3a15.12.3-0ubuntu1_amd64.deb E: Sub-process /usr/bin/dpkg returned an error code (1)
Any suggestions?
