I tried installing webmin through the apt-get method. Then I tried reinstalling it because I messed up the config without backing it up. So I removed it and then tried to install it.
My full log:
root@278420-1484:~# apt-get install webmin
Reading package lists... Done
Building dependency tree
The following NEW packages will be installed:
webmin
0 upgraded, 1 newly installed, 0 to remove and 0 not upgraded.
Need to get 0 B/15.2 MB of archives.
After this operation, 161 MB of additional disk space will be used.
(Reading database ... 37754 files and directories currently installed.)
Preparing to unpack .../archives/webmin_1.820_all.deb ...
Port 10000 is already in use
dpkg: error processing archive /var/cache/apt/archives/webmin_1.820_all.deb (--unpack):
subprocess new pre-installation script returned error exit status 2
root@278420-1484:~#
I already tried apt-get clean, apt-get update and other methods I found on the internet but nothing got it to work. Please help me.
