I am trying to install packages with this command:
sudo apt-get -f install lib32z1 lib32ncurses5 lib32stdc++6
But I am getting errors during the installation. Error looks like:
pkg-name : Depends: pkg-name (= X.X) but it is not going to be installed
Here are some screenshots:
Errors - 1
Errors - 2
Any suggestions?
edwinksl
  • 24,109
Those packages have been replaced under the newer multiarch specification, so add :i386 to specify the 32-bit version if you are running a 64-bit system, otherwise APT will assume you want the 64-bit version.
This works for me in Ubuntu 16.04:
sudo apt install zlib1g:i386 libncurses5:i386 libstdc++6:i386
Thanks to comment by TONTONFLASH leading to the other post where another comment by steeldriver gave the necessary hint.
Zanna
  • 72,312
1. Enter this command:
This is an 'apt' command to fix dependencies ("-f").
2. Then enter this command:
sudo dpkg --configure -a
3. Lastly enter this command (from 'Step 1'):
0 upgraded, 0 newly installed, 0 to remove and 1 not upgraded.
This output indicates that the above did not work
