apache ask for passphrase redirects to plymouth even when I'm remoted in using SSH and away from console.
How can I disabled plymouth?
Update: I did learn that I can sudo plymouth --quit and that will shutdown plymouth. I would like to know the recommended way to disable plymouth on boot.
jokerdino
  • 41,732
plymouth should be stopping on its own when the boot is finished.. on a GUI that is when kdm/xdm/gdm/lxdm start. On servers, that is when runlevel 2 is finished (ls /etc/rc2.d). If it is not stopped, this is likely a bug in the bootup, and should be reported with
apport-bug plymouth
Additional Resources:
SpamapS
  • 20,110
The How can I disable the purple splash screen at boot? has been mentioned.
You could also edit the plymouth /1/ upstart /2/ config files and prevent the plymouth start-up. I think that the /etc/init/plymouth.conf will do the trick.
Links:
  1. https://wiki.ubuntu.com/Plymouth
  2. http://upstart.ubuntu.com/
user26687
  • 15,174
