14
I recently upgraded to Ubuntu 16.04. Unfortunately I need to work MySQL 5.5 or 5.6. I tried many solutions to have MySQL 5.5 or 5.6 run on Ubuntu 16.04 like this Install MySql 5.6 on Ubuntu 16.04 . But none of them is working. Ubuntu detect the unmet dependencies but says "but it is not going to be installed" for 5.5 or says Package 'mysql-server-5.6' has no installation candidate...
Is it not possible to force an earlier version of MySQL on Ubuntu? Why is that?
idris
  • 161
Step by step guide* to install mysql 5.5.x on Ubuntu 16.04 Xenial-Xerus. Please see this documentation
OR
See steps below:
Installing MySQL 5.5.51 on Ubuntu 16.06
  1. Uninstall any existing version of MySQL
    sudo rm /var/lib/mysql/ -R
  2. Delete the MySQL profile
    sudo rm /etc/mysql/ -R
  3. Automatically uninstall mysql
    sudo apt-get autoremove mysql* --purge
    sudo apt-get remove apparmor
  4. Download version 5.5.51 from MySQL site
    wget https://dev.mysql.com/get/Downloads/MySQL-5.5/mysql-5.5.56-linux-glibc2.5-x86_64.tar.gz
  5. Add mysql user group
    sudo groupadd mysql
  6. Add mysql (not the current user) to mysql user group
    sudo useradd -g  mysql mysql
  7. Extract mysql-5.5.51-linux2.6-x86_64.tar.gz to /usr/local
    cd /usr/local
    sudo tar -xvf mysql-5.5.49-linux2.6-x86_64.tar.gz
  8. Create mysql folder in /usr/local
    sudo mv mysql-5.5.49-linux2.6-x86_64 mysql
  9. Set mysql directory owner and user group
    cd mysql
    sudo chown -R mysql:mysql *
  10. Install the required lib package
    sudo apt-get install libaio1
  11. Execute mysql installation script
    sudo scripts/mysql_install_db --user=mysql
  12. Set mysql directory owner from outside the mysql directory
    sudo chown -R root .
  13. Set data directory owner from inside mysql directory
    sudo chown -R mysql data
  14. Copy the mysql configuration file
    sudo cp support-files/my-medium.cnf /etc/my.cnf
  15. Start mysql
    sudo bin/mysqld_safe --user=mysql &
    sudo cp support-files/mysql.server /etc/init.d/mysql.server
  16. Initialize root user password
    sudo bin/mysqladmin -u root password '111111'
  17. Start mysql server
    sudo /etc/init.d/mysql.server start
  18. Stop mysql server
    sudo /etc/init.d/mysql.server stop
  19. Check status of mysql
    sudo /etc/init.d/mysql.server status
  20. Enable myql on startup
    sudo update-rc.d -f mysql.server defaults
  21. Disable mysql on startup (Optional)
    sudo update-rc.d -f mysql.server remove
  22. Add mysql path to the system
    sudo ln -s /usr/local/mysql/bin/mysql /usr/local/bin/mysql
  23. Now directly use the command below to start mysql
    mysql -u root -p
PS: One needs to reboot in order for the changes to take place.
Based on a Chinese blog
David Foerster
  • 36,890
  • 56
  • 97
  • 151
Try this, First you have to remove
sudo rm /var/lib/mysql/debian-5.7.flag
then
sudo add-apt-repository 'deb http://archive.ubuntu.com/ubuntu trusty universe'
sudo apt-get update
sudo apt install mysql-server-5.6
sudo apt install mysql-client-5.6
This answer helped me figure out how to do it by downloading the .deb packages from MySQL dev site. The solution about adding the PPA did not do it for me.
It links to a blogpost: How to Install MySQL-5-6 on Ubuntu Precise Tricky but it works.
idris
  • 161
A simpler alternative is to use Percona Server. By their documentation:
Installing Percona Server from Percona apt repository
  1. Fetch the repository packages from Percona web:
    wget https://repo.percona.com/apt/percona-release_0.1-4.$(lsb_release -sc)_all.deb
  2. Install the downloaded package with dpkg. To do that, run the following commands as root or with sudo:
    dpkg -i percona-release_0.1-4.$(lsb_release -sc)_all.deb
    Once you install this package the Percona repositories should be added. You can check the repository setup in the /etc/apt/sources.list.d/percona-release.list file.
  3. Remember to update the local cache:
    apt-get update
  4. After that you can install the server package:
    apt-get install percona-server-server-5.5
