I am getting the following error while install mysql
Steps I did : Downloaded apt file from here http://dev.mysql.com/downloads/repo/apt/ run this command
sudo dpkg -i path
In that there is no option to select 5.5 so I selected 5.6 then
sudo apt-get update
sudo apt-get install mysql-server
but it gives error
mysql-server : Depends: mysql-server-5.5 but it is not going to be installed
/etc/apt/sources.list : http://pastebin.com/PwJX2pi6
/etc/apt/sources.list.d :
kubuntu-ci-stable-trusty.list
kubuntu-ci-stable-trusty.list.save
pwntools-binutils-trusty.list
pwntools-binutils-trusty.list.save
rvm-smplayer-trusty.list
webupd8team-java-trusty.list
webupd8team-java-trusty.list.save
