I created a partition in Windows 7 in anticipation of installing Ubuntu 16.04 to run as dual boot system.
While installing the OS I chose the automatic option instead of the DIY path. Both OS's are running fine but Ubuntu created a 5th partition (very small) and the one I created with about 60gb seems to be empty still. Can I delete that partition? Will the balance go to the C:\ drive?
Should I start all over and let Ubuntu create the partitions? Does Ubuntu require its own partitions?
Model: ATA WDC WD1600AAJS-7 (scsi)
Disk /dev/sda: 160GB
Sector size (logical/physical): 512B/512B
Partition Table: msdos
Disk Flags:
Number Start End Size Type File system Flags
1 1049kB 12.6GB 12.6GB primary ntfs diag
2 12.6GB 14.7GB 2140MB primary ntfs boot
3 14.7GB 94.7GB 80.0GB primary ntfs
4 94.7GB 160GB 65.3GB extended
5 94.7GB 156GB 61.6GB logical ext4
6 156GB 160GB 3721MB logical linux-swap(v1)
tim@tim-ThinkCentre-M58p:~$
