Preliminary ubuntu 16.04 dual boot on a disk that also runs windows 10 hibernate works in windows 10 swap partition is the same size as RAM
Problem When I run sudo pm-hibernate from the terminal nothing happens. The line advances as though the command has been run but there's no action. If i try to check the log in /var/log/ there's no file for pm-hibernate. However there is a log for pm-suspend.
i've checked the pm-suspend file but it is not recording any information when i try to hibernate. the pm-suspend file gets updated when i run sudo pm-suspend from the terminal.
