My computer recently started freezing a lot. The freezing affects everything but the power button. Each time it freezes I have to restart my computer and this is really affecting my productivity. Thanks in advance. My question is how do I figure out what is causes the freezes and then fix that.
Asked
Active
Viewed 951 times
You can see resources utilization of CPU and RAM for each process by running on a terminal the command :
top
You can also check the RAM actually in use with this command :
free -tm
If when your computer freeze you can't check which process cause the problem with top you can according to this check the log with :
In a terminal :
tail -f /var/log/syslog
If you are running gnome, then you can check the logs using "gnome-system-log"
To launch a terminal according to this you can do :
- If you're running Unity: open the dash, type
terminal, hitReturn. - If you're on the old style menus, Applications → Accessories → Terminal.
Control+Alt+T.Alt+F2,gnome-terminal,Return.
After that you just had to type the command and hit enter.
When you run top there a 3 important column for you, each line in top represent a process .
- At the middle you can see behind the %CPU the % of CPU in use for a process.
- At the right of the %CPU you have %MEM which represent the ram.
- And at the just right you have command which is the process name corresponding to the use of CPU and MEM .
jeremy.Snidaro
- 306
