I am trying to tweak the touchpad on Ubuntu 16.04 but none of the usual methods seem to work. e.g.
synclient touchpadOff=1
It still works!
$ xinput set-prop $DEVICE_ID "Device Enabled" 0
$ xinput list-props 15 |head -n2
Device 'SynPS/2 Synaptics TouchPad':
Device Enabled (168): 0
...it still works!
I can disable it from the Settings app. but I want to be able to map this to a keyboard shortcut, so I'm looking for a command line solution.
Bonus points if you answer works in Gnome-Shell as well as Unity :-)
EDIT: output of xinput as requested in comment.
$ xinput
⎡ Virtual core pointer id=2 [master pointer (3)]
⎜ ↳ Virtual core XTEST pointer id=4 [slave pointer (2)]
⎜ ↳ ELAN Touchscreen id=12 [slave pointer (2)]
⎜ ↳ DLL06E4:01 06CB:7A13 Touchpad id=13 [slave pointer (2)]
⎜ ↳ SynPS/2 Synaptics TouchPad id=15 [slave pointer (2)]
⎣ Virtual core keyboard id=3 [master keyboard (2)]
↳ Virtual core XTEST keyboard id=5 [slave keyboard (3)]
↳ Power Button id=6 [slave keyboard (3)]
↳ Video Bus id=7 [slave keyboard (3)]
↳ Video Bus id=8 [slave keyboard (3)]
↳ Power Button id=9 [slave keyboard (3)]
↳ Sleep Button id=10 [slave keyboard (3)]
↳ Integrated_Webcam_HD id=11 [slave keyboard (3)]
↳ AT Translated Set 2 keyboard id=14 [slave keyboard (3)]
↳ Dell WMI hotkeys id=16 [slave keyboard (3)]
Nb. I have used 15 for $DEVICE_ID
EDIT - thanks to the answer below here's my toggle script
You can do it in a one liner, but this way you get a nice notification, too. I've attached this to a shortcut key and it works a charm. Thanks all.
#!/bin/bash
if xinput list-props 13 | grep "Device Enabled (168):.*1" >/dev/null
then
xinput disable 13
notify-send -u low -i mouse "Trackpad disabled"
else
xinput enable 13
notify-send -u low -i mouse "Trackpad enabled"
fi
