Thinkpad laptop W520 series with kernel: 4.15.0-51-generic x86_64 bits: 64
Following the latest dist-update the trackpoint and it's related keys don't work after return from suspend mode. Unloading and (re-)loading of psmouse fixes the issue but is only a workaround and somewhat annoying.
TLP is installed.
Any help highly appreciated. mgw
====== update ======
Finally, replacing the palmrest fixed everything due to the fact that this behavior stems from a hardware failure. The touchpad simply gave up after 10+ years and this also had a side effect on the trackpoint - please note that the trackpoint hasn't been replaced and I'm still typing happily on the original keyboard from 2011.
mgw
  • 174
Having to unload and reload the psmouse driver when resuming from suspend is a common problem. You can automate the process with a script though:
Create a new file in the /lib/systemd/system-sleep/ directory containing:
#!/bin/bash
case $1/$2 in pre/) echo "Going to $2..." # Place your pre suspend commands here, or exit 0 if no pre suspend action required modprobe -r psmouse ;; post/) echo "Waking up from $2..." # Place your post suspend (resume) commands here, or exit 0 if no post suspend action required sleep 2 modprobe psmouse ;; esac
Make it executable:
sudo chmod a+x /lib/systemd/system-sleep/script-name
After the next reboot, the script will be active.
A script like this has worked for many people over the years. Of course your other option would be trying the previous kernel version and if it works sticking with it.
Notes when your script isn't working:
  • Ensure the systemd suspend target is enabled.
  • From the same accepted answer in the link, you may need to set PATH for external commands by inserting the following command into your script. Add any additional directories your commands may be in:
    PATH=/sbin:/usr/sbin:/bin:/usr/bin
  • If it still isn't working, post a new question. Then drop a comment below with a link to the new question and I'll have a look.
mgw
  • 174
I'm having the same isse with a ThinkPad E14 Gen2 and this has been bugging me for years. Using "Windows" suspend mode in UEFI works - but it drains the battery much faster. The solution was to create a workaround script with a systemd unit.
Save this script to some file like /usr/local/bin/trackpoint-fix, then make it executable.
#!/bin/bash
echo -n "none" | sudo tee /sys/bus/serio/devices/serio1/drvctl
sleep 3
echo -n "reconnect" | sudo tee /sys/bus/serio/devices/serio1/drvctl
Then create a systemd unit: sudo systemctl edit --force --full trackpoint-fix.service
[Unit]
Description=Fixes trackpoint
[Service] Type=oneshot ExecStart=/usr/local/bin/trackpoint-fix TimeoutSec=0 StandardOutput=syslog
[Install] WantedBy=multi-user.target sleep.target
Lastly, enable it: sudo systemctl enable trackpoint-fix
Works like a charm for me!
gombosg
  • 121
