30
I'm going to be installing Ubuntu 15.10 soon after a break from Linux for a while. I would like to know if nomodeset is still required on newer Ubuntu releases and newer nVidia GPUs. I have a GTX970.
Also, would be better to install the proprietary driver from nVidia, or choose the driver from "Additional Drivers", or use the edgers PPA and grab the latest one from there?
cl-netbox
  • 31,491
xXToYeDXx
  • 303
You should use the parameter nouveau.modeset=0 instead of nomodeset.
Install the Ubuntu system and the proprietary NVIDIA drivers in this way :
Boot from the Ubuntu DVD/USB installation media you had created before.
Highlight the option 'Try Ubuntu without installing' and press the E key.
Add nouveau.modeset=0 to the end of the linux line - press F10 to boot.
Install the Ubuntu operating system - when finished reboot the computer.
Highlight the Ubuntu entry in the GRUB boot menu and press the E key.
On the login screen press Ctrl+Alt+F1
Enter user name and password - execute :
sudo apt-get update
sudo apt-get install nvidia-352
sudo reboot
Generally it is recommended to use the NVIDIA drivers from the official Ubuntu repositories.
But as you have very new graphics hardware, you can install the latest official NVIDIA drivers.
The xorg-edgers PPA does not provide the drivers anymore and was replaced by GPU Drivers.
sudo add-apt-repository ppa:graphics-drivers/ppa
sudo apt-get update
sudo apt-get install nvidia-361
sudo reboot
After the installation adding the parameter nouveau.modeset=0 is not necessary anymore.
cl-netbox
  • 31,491
I had the same problem with my Xubuntu 18.04 version that runs on Nvidia GPU. I tried to installed the latest Nvidia-390 and nvidia-prime drivers and updated my driver installs as these solutions show [1] [2], and I added nouveau to the block list, but none of these worked. So what I did is that I added the parameternouveau.modeset=0 to grub.cfg file in \boot\grub\ directory. I added the line after every "linux..." line, for instance:
menuentry 'FAILSAFE' --class ubuntu --class gnu-linux --class gnu --class os {
    recordfail
    set gfxpayload=$linux_gfx_mode
    insmod part_msdos
    insmod ext2
    set root='(hd0,msdos8)'
    search --no-floppy --fs-uuid --set=root 36286167-4eba-4a1e-a202-155c6baafa01
    linux /boot/vmlinuz-2.6.37-12-generic root=UUID=36286167-4eba-4a1e-a202-155c6baafa01 ro vt.handoff=7 quiet splash nouveau.modeset=0
    initrd /boot/initrd.img-2.6.37-12-generic
So, I believe you have to add this parameter in all the script. I tried this solution and Nvidia GPU driver stopped crashing.
Another approach as described here
Execute sudo nano /etc/default/grub and add the parameter nvidia-drm.modeset=1 to the line GRUB_CMDLINE_LINUX_DEFAULT. Save the change you've made and run sudo update-grub.
Restart the Ubuntu operating system, and now, everything should work properly - right as expected.
debugging XD
  • 141
Just an observation: our machines with NVIDIA GTX 10xx GPUs and Ryzen CPUs often got stuck with "soft lockup" and needed hard restart. Other machines with nomodeset and also the said machines after this setting did not get stuck. So there seems to be causality beyond boot.
See also: NMI Watchdog: BUG: soft lockup
No, it's not required anymore. I was also facing similar problem. Using nomodeset I can boot into the system but now I solved the problem another way round. Only thing we need to do is to upgrade or downgrade the kernel version. https://askubuntu.com/a/1014753 This forum has explained how to access advanced option in ubuntu. Now when we enter into advanced option we can see linux kernel versions like: https://i.sstatic.net/6PEl9.png
  • Now navigate to the lower version of kernel using arrow keys but leave all the recovery modes kernels.
  • Leaving the recovery modes kernel, select the lowest version of kernel and hit enter.
  • Now it will boot normally without using nomodeset. Remove nomodeset before if you have written it in grub file and update the grub.
  • Now to make changes permanent go through this below given link and remove all the above kernels but don't remove the running kernels.
https://itsfoss.com/upgrade-linux-kernel-ubuntu/ This link will guide us through the procedure to update or downgrade the kernel. For me kernel 5.3 worked perfectly fine.
Amey
