Is there a way to display something (a warning, a persistent icon that I could change, anything) in the system-tray in Unity? I need to be able to control it from a bash script.
Ideally this would be a command that could control an area in the systray and give messages about the status of the script I'm running. So probably it does not have to be Unity specific, just be compatible with it.
Indicator System Monitor
indicator system monitor
The closest method I've found to satisfy your requirements is (webupd8.org - Ubuntu appindicator that displays bash) that displays text on the Unity system tray / application indicator bar. The sample above comes from two bash scripts: multi-timer and display-auto-brightness.
Install and Configure Sysmonitor Indicator
You need to install indicator-sysmonitor from ppa:
sudo add-apt-repository ppa:fossfreedom/indicator-sysmonitor
sudo apt-get update
sudo apt-get install indicator-sysmonitor
Then run the gui and configure it with the script name that updates the system tray.
Sample scripts to output to system tray
Here are a few examples from the WebUpd8 link above:
  • Display the current CPU frequency for the first core:
    echo $(grep "cpu MHz" /proc/cpuinfo | head -1 | cut -d ' ' -f3 | cut -d '.' -f1) MHz
  • Check if a website is up (smiley face) or down (sad face):
    if wget -O /dev/null webupd8.org > /dev/null; then echo "☺"; else echo "☹"; fi
Did you look into notify-send? Works great for temporary messages, I think it's in all of the Ubuntu desktops (definitely in XFCE) or should be available with a quick apt command.
Has options like:
-u, --urgency=LEVEL Specifies the urgency level (low, normal, critical).
-t, --expire-time=TIME
          Specifies the timeout in milliseconds at which to expire
          the notification.
-i, --icon=ICON[,ICON...]
          Specifies an icon filename or stock icon to display.
-c, --category=TYPE[,TYPE...]
          Specifies the notification category.
Man page also says:
SEE ALSO
The Desktop Notification Spec on http://www.galago-project.org/specs/notification/
Xen2050
  • 8,943
Take a look at alltray; maybe it's your solution.
From its website:
Description
With AllTray you can dock any application with no native tray icon (like Evolution, Thunderbird, Terminals) into the system tray. A high-light feature is that a click on the "close" button will minimize back to system tray. It works well with Gnome, KDE, XFCE 4*, Fluxbox* and WindowMaker*. Xmms is supported in particular.
Options
These programs follow the usual GNU command line syntax, with long options starting with two dashes ('-'). A summary of options is included below.
-h --help | Show summary of options.
-v --version | Show version of program.
-d --debug | Show debug messages.
-s --show | Do not hide window after start.
-i --icon | Use a PNG image as an icon.
-l --large_icons | allow large icons (> 24x24).
-st --sticky | visible on all workspaces.
-x --borderless | Remove windows decorations border, title, frame... from parent.
-m --menu | Add entry "menu text:command" to popdown menu.
-t --title | Show title change for seconds. Probably most usefull for xmms.
-g --geometry | initial position. see man X.
Installation (command in a terminal)
sudo apt-get install alltray
Cheers
