How to install a wireless adapter D-Link DWA-131?
The solution which worked under Ubuntu 14.04.1 is not working under Ubuntu 14.04.4.
Even the make process itself gives errors.
Is there any permanent solution for this without any worries for higher Ubuntu version?
nb5691
  • 65
Please open a terminal and, with a temporary working internet connection, do:
sudo apt-get install git
git clone https://github.com/Mange/rtl8192eu-linux-driver.git
cd rtl8192eu-linux-driver
make
sudo make install
sudo modprobe 8192eu
Your wireless should now be working.
You will have installed the driver for your current kernel version only. After Update Manager installs a later kernel version, also known as linux-image, after the requested reboot, you must recompile:
make clean
make
sudo make install
Please retain the file and these instructions for that time.
chili555
  • 61,330
I added this driver to my ppa. It builds for kernels 4.2.
If you install it from the PPA, then you will not have to re-install it after kernel updates.
The driver can be installed by running
sudo add-apt-repository ppa:hanipouspilot/rtlwifi
sudo apt-get update
sudo apt-get install rtl8192eu-dkms
If you installed a driver from github, you need to uninstall it first.
Pilot6
  • 92,041
