Recently I built new PC with Ubuntu OS 14.04 (64bit). I noticed the D-Link Wireless N Nano USB Adapter doesn't get detected and installed automatically.
Following are the adapter specifications:
  • Model No: DWA-131
  • Hardware Version : E1
  • Firmware Version : 5.00
How to install this wireless adapter?
I added a driver for this adapter to PPA. It can be installed by running:
sudo add-apt-repository ppa:hanipouspilot/rtlwifi
sudo apt-get update
sudo apt-get install rtl8192eu-dkms
Pilot6
  • 92,041
Here's exactly what and where you have to edit:
  • Download the source of the DWA-131 (version E1) Linux driver.
  • Extract your source and go to /20140812_rtl8192EU_linux_v4.3.1.1_11320/os_dep/linux/.
  • Edit the os_intfs.c file.
  • Search for the following line: DBG_871X_LEVEL(_drv_info and change
    #endif
            return NOTIFY_DONE;
        DBG_871X_LEVEL(_drv_info_, FUNC_NDEV_FMT" state:%lu\n", FUNC_NDEV_ARG(dev), state);
        switch (state) {
        case NETDEV_CHANGENAME:
            rtw_adapter_proc_replace(dev);
            break;
        return NOTIFY_DONE;
    into
    #endif
            return NOTIFY_DONE;
        //ed, 20150426 //DBG_871X_LEVEL(_drv_info_, FUNC_NDEV_FMT" state:%lu\n", FUNC_NDEV_ARG(dev), state);
        switch (state) {
            //ed,20150426 //rtw_adapter_proc_replace(dev);
            break;
        return NOTIFY_DONE;
    You have to actually insert this: //ed, 20150426 //
  • Then write the file and do:
    1. make
    2. make install
  • I also did the following:
    wget http://www.orbit-lab.org/kernel/compat-wireless-3-stable/v3.0.0/compat-wireless-3.0-2.tar.bz2
    tar jxvf compat-wireless-3.0-2.tar.bz2
    make
    make install
    (Please note that the build-essential package is already installed on the machine. You'll have to apt-get install it if you want to be able to make and make install anything on the machine.)
Hope this helps make the process clearer. Thanks to the first author for the files to modify.
Fabrice Clerc
I have faced this issue after upgrading from 18.04 to Ubuntu 20.04. The goal is to download the last driver for rtl8192eu adapted to the newest kernels (up to 5.18)
Install Drivers in new Kernel versions
  1. Go to this Github repo and download the adpated Driver https://github.com/clnhub/rtl8192eu-linux
  • TIP: If you don't have internet access in the PC, use your phone, set the Desktop view (i.e. Chrome) and download the repo selecting "CODE" --> "Download ZIP" and then copy the .zip file into the PC.
  1. Build the Driver using the automated script ./install_wifi.sh
  • IMPORTANT: It is necessary to have installed those packages "linux-headers-generic build-essential dkms".
  1. After finishing the script (and without restarting) the WiFi icon will be shown in the Task Bar (up right corner).
Path to the official linux drivers In this path are located the official released drivers --> But only supports 18.04
Nothor
  • 111
This way is working on my desktop (x86_64, ubuntu 14.04, kernel 3.13.0-49-generic). For your reference.
  1. Download the source of the DWA-131 (ver:E1) linux driver.
  2. Extract the zip file (DWA-131_Linux_driver_v4.3.1.1.zip)
  3. Modify two lines (//ed, 20150426 //...) in the rtw_ndev_notifier_call() function, file name os_intfs.c.
    return NOTIFY_DONE;
    switch (state) {    case NETDEV_CHANGENAME:         //ed, 20150426 //rtw_adapter_proc_replace(dev);         break;  }
  4. compile the codes. (refer to readme.txt in the downloaded package)
    make
  5. install the driver
    sudo make install
