I'm pretty new to Ubuntu, however I have taken some effort to follow some of the solutions from others on here with similar versions of my hardware, to no avail. Some of the solutions I've tried.
  1. Install DWA-131 WiFi dongle driver under Ubuntu 14.04.4
  2. D-Link DWA-130 rev E1 RTL8191SU Wont Connect to Network (14.04)
I'm getting desperate at this point. What am I missing? Please help!
I have a Windows 10 dual boot which runs the same USB adaptor at a much higher speed so I know the issue is not with the WiFi signal. (70+ Mbps vs 2-3 Mbps in Ubuntu)
My current Ubuntu version is 16.04 LTS and I get 4.13.0-32-generic. From uname -r
The result from lsusb is:
Bus 002 Device 004: ID 8087:0aa7 Intel Corp.
Bus 002 Device 003: ID 0bda:0153 Realtek Semiconductor Corp. Mass Storage Device
Bus 002 Device 002: ID 0438:7900 Advanced Micro Devices, Inc.
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 001 Device 004: ID 0461:4e6f Primax Electronics, Ltd
Bus 001 Device 003: ID 04ca:008a Lite-On Technology Corp.
Bus 001 Device 002: ID 0438:7900 Advanced Micro Devices, Inc.
Bus 004 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 003 Device 003: ID 2001:3c25 D-Link Corp.
Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
My result from lsmod | grep ^rt is:
rt2800usb              28672  0
rt2x00usb              20480  1 rt2800usb
rt2800lib             110592  1 rt2800usb
rt2x00lib              53248  3 rt2800lib,rt2800usb,rt2x00usb
My result from sudo lshw -class network
*-network
       description: Wireless interface
       product: Intel Corporation
       vendor: Intel Corporation
       physical id: 0
       bus info: pci@0000:01:00.0
       logical name: wlp1s0
       version: 10
       serial: b0:35:9f:76:20:f5
       width: 64 bits
       clock: 33MHz
       capabilities: pm msi pciexpress bus_master cap_list ethernet physical wireless
       configuration: broadcast=yes driver=iwlwifi driverversion=4.13.0-32-generic firmware=29.610311.0 latency=0 link=no multicast=yes wireless=IEEE 802.11
       resources: irq:41 memory:fe900000-fe901fff
  *-network
       description: Ethernet interface
       product: RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller
       vendor: Realtek Semiconductor Co., Ltd.
       physical id: 0
       bus info: pci@0000:02:00.0
       logical name: enp2s0
       version: 11
       serial: 98:ee:cb:62:06:d1
       capacity: 1Gbit/s
       width: 64 bits
       clock: 33MHz
       capabilities: pm msi pciexpress msix vpd bus_master cap_list ethernet physical tp mii 10bt 10bt-fd 100bt 100bt-fd 1000bt 1000bt-fd autonegotiation
       configuration: autonegotiation=on broadcast=yes driver=r8169 driverversion=2.3LK-NAPI duplex=half firmware=rtl8168g-2_0.0.1 02/06/13 latency=0 link=no multicast=yes port=MII speed=10Mbit/s
       resources: irq:35 ioport:e000(size=256) memory:fe800000-fe800fff memory:d0800000-d0803fff
  *-network
       physical id: 1
       bus info: usb@3:1
       logical name: wlx74dada32f98d
       serial: 74:da:da:32:f9:8d
       capabilities: ethernet physical wireless
       configuration: broadcast=yes driver=rt2800usb driverversion=4.13.0-32-generic firmware=0.29 ip=192.168.0.26 link=yes multicast=yes wireless=IEEE 802.11
patebin containing my wireless info.
Thanks in advance!
jnnnn
