If I run ubuntu on a flash stick as the instructions say, then install it, where does it install to? I have windows 10 and windows 7 on two different disks on a Asus computer with 16 GB memory, and want to run ubuntu on a different drive but not mess up the boot manager by installing it on one of the two disks internally. Someone explain the process of how to run ubuntu on a flash stick without messing up the boot manager on the uefi bios .
GAD3R
  • 3,748
If you dont want to install the linux, which is what I am assuming you mean by "how to run ubuntu on a flash stick". You can look at this link running linux on a usb stick wont effect bios you just interrupt the boot order for that one boot.
You will just need to interrupt your boot order for each boot you do this. A quirky video on how to do that.
You have two other options install linux onto one of your drives and and you can use the grub men to boot to either linux windows 7 or 10 anytime you boot. here is a well thought out and well written guide for windows 10
Your other option depending on your need you can use a virtual machine, which would have no effect at all on your bios. And if you ever have any problems with it you can delete it. Here's a link to see how to
adobesmurf
  • 106
