have looked these questions,
13.04 login: lagging after password entry for several seconds
Ubuntu 12.04 desktop loads pretty slow after password entry
All questions address boot problem, the cause is different, hence attaching a log file, If it shows the reason for the delay.
It is a Kubuntu 15.10 system,
The system goes normal till entering the password. After the password is entered, the system gets slower to load the panels and menus. mouse is available even ctrl + Esc works, but not menus.
the log,
[ 19.996858] nvidia: module license 'NVIDIA' taints kernel.
[ 19.996865] Disabling lock debugging due to kernel taint
[ 20.006872] nvidia: module verification failed: signature and/or required key missing - tainting kernel
[ 20.013589] vgaarb: device changed decodes: PCI:0000:01:00.0,olddecodes=io+mem,decodes=none:owns=io+mem
[ 20.013967] [drm] Initialized nvidia-drm 0.0.0 20150116 for 0000:01:00.0 on minor 0
[ 20.013976] NVRM: loading NVIDIA UNIX x86_64 Kernel Module 352.63 Sat Nov 7 21:25:42 PST 2015
[ 20.864120] Adding 2949116k swap on /dev/sda6. Priority:-1 extents:1 across:2949116k FS
[ 22.152779] IPv6: ADDRCONF(NETDEV_UP): enp3s0: link is not ready
[ 22.241323] r8169 0000:03:00.0 enp3s0: link down
[ 22.241335] r8169 0000:03:00.0 enp3s0: link down
[ 22.241377] IPv6: ADDRCONF(NETDEV_UP): enp3s0: link is not ready
[ 24.384687] r8169 0000:03:00.0 enp3s0: link up
[ 24.384704] IPv6: ADDRCONF(NETDEV_CHANGE): enp3s0: link becomes ready
[ 2105.330193] PM: Syncing filesystems ... done.
[ 2105.607910] PM: Preparing system for sleep (mem)
[ 2106.055124] Freezing user space processes ... (elapsed 0.001 seconds) done.
[ 2106.057091] Freezing remaining freezable tasks ... (elapsed 0.001 seconds) done.
[ 2106.058232] PM: Suspending system (mem)
[ 2106.058309] Suspending console(s) (use no_console_suspend to debug)
[ 2106.058947] sd 3:0:0:0: [sdb] Synchronizing SCSI cache
[ 2106.059053] sd 2:0:0:0: [sda] Synchronizing SCSI cache
[ 2106.061721] sd 2:0:0:0: [sda] Stopping disk
[ 2106.061771] sd 3:0:0:0: [sdb] Stopping disk
[ 2106.062144] serial 00:03: disabled
[ 2106.062150] serial 00:03: System wakeup disabled by ACPI
[ 2106.572053] PM: suspend of devices complete after 513.339 msecs
[ 2106.572634] PM: late suspend of devices complete after 0.578 msecs
I see the delay is between
and
what is the reason? how to fix it? thanks.
