When I login to my Ubuntu 13.04 beta2 (std Unity) session, after I enter the password, there is a deferral of some seconds which is not there on my 12.04. LTS partition.
Can this be related to the dmesg output:
[   37.101723] systemd-logind[2350]: New seat seat0.
[   37.101785] systemd-logind[2350]: Failed to save seat data for seat0: No such file or directory
and if so, what does it mean? I tried to google that lines but could not find any helpful references.
Using aptitude gave me the following information:
aptitude search systemd
p libpam-systemd - system and service manager - PAM module
p libpam-systemd:i386 - system and service manager - PAM module
p libsystemd-daemon-dev - systemd utility library - development files
p libsystemd-daemon-dev:i386 - systemd utility library - development files
i libsystemd-daemon0 - systemd utility library
p libsystemd-daemon0:i386 - systemd utility library
p libsystemd-id128-0 - systemd 128 bit ID utility library
p libsystemd-id128-0:i386 - systemd 128 bit ID utility library
p libsystemd-id128-dev - systemd 128 bit ID utility library - development
p libsystemd-id128-dev:i386 - systemd 128 bit ID utility library - development
p libsystemd-journal-dev - systemd journal utility library - development files
p libsystemd-journal0 - systemd journal utility library
p libsystemd-journal0:i386 - systemd journal utility library
p libsystemd-login-dev - systemd login utility library - development file
p libsystemd-login-dev:i386 - systemd login utility library - development file
p libsystemd-login0 - systemd login utility library
p libsystemd-login0:i386 - systemd login utility library
p live-config-systemd - Live System Configuration Scripts (systemd backend)
p python-systemd - python bindings for the systemd journal
p python-systemd:i386 - python bindings for the systemd journal
i systemd-services - systemd runtime services
p systemd-services:i386 - systemd runtime services
i systemd-shim - shim for systemd
p systemd-shim:i386 - shim for systemd
Luis Alvarado
  • 216,643
For me, I removed the libsystemd-login0 package and rebooted. I know it is a login manager but my system it is still running. Also I find this odd since I thought upstart was the alternative to systemd. Anyway just do the following:
sudo apt-get remove libsystemd-login0
It gave me about a 1 to 2 second freeze until I removed the package. If it is going to be needed in the future, I will leave it like that until the time comes when another package needs it. You can find more info about the move to systemd in this Phoronix article.
UPDATE: Comparing your aptitude list to mine I would ask you to reinstall/install the following packages:
sudo aptitude reinstall libsystemd-daemon0 systemd-services systemd-shim
sudo aptitude install libsystemd-id128-0 libsystemd-journal0 python-systemd
This will leave you exactly like I am right now:
cyrex@cyrex:~$ aptitude search systemd
i A libsystemd-daemon0        - systemd utility library
i   libsystemd-id128-0        - systemd 128 bit ID utility library
p   libsystemd-id128-dev        - systemd 128 bit ID utility library - development files
p   libsystemd-id128-dev:i386        - systemd 128 bit ID utility library - development files
p   libsystemd-journal-dev:i386                                                               - systemd journal utility library - development files
i   libsystemd-journal0        - systemd journal utility library
p   libsystemd-login-dev        - systemd login utility library - development files
p   libsystemd-login-dev:i386        - systemd login utility library - development files
c   libsystemd-login0        - systemd login utility library
i   python-systemd        - python bindings for the systemd journal
i A systemd-services        - systemd runtime services
i A systemd-shim        - shim for systemd
Don't mind the c state for the login package. I just did not delete the configuration files after removing the package. If the freezing still shows then I created an bug report here: https://bugs.launchpad.net/ubuntu/+source/shadow/+bug/1167642
Luis Alvarado
  • 216,643
