How can I install firmware-b43-installer driver if I can't connect to internet by wire?
You need to install firmware-b43-installer.
If you do not have an alternative internet connection, do it this way.
If you installed bcmwl-kernel-source, then remove it.
sudo apt-get purge bcmwl-kernel-source
- Download these files
http://mirrors.kernel.org/ubuntu/pool/main/b/b43-fwcutter/b43-fwcutter_015-9_amd64.deb http://www.lwfinger.com/b43-firmware/broadcom-wl-5.100.138.tar.bz2
Copy them to your Ubuntu Home folder.
Run in terminal
sudo dpkg -i b43-fwcutter_015-9_amd64.deb tar xfvj broadcom-wl-5.100.138.tar.bz2 sudo b43-fwcutter -w /lib/firmware broadcom-wl-5.100.138/linux/wl_apsta.oReboot or run:
sudo modprobe b43
Note: For 32-bit systems download http://mirrors.kernel.org/ubuntu/pool/main/b/b43-fwcutter/b43-fwcutter_019-2_i386.deb instead of amd64 and update the file name in the dpkg command.
For Ubuntu 16.04 http://mirrors.kernel.org/ubuntu/pool/main/b/b43-fwcutter/b43-fwcutter_019-2_amd64.deb should be installed or the i386 alternative.
If you are having trouble finding another computer, an Android phone can be used as a USB modem. You can connect the phone and choose "USB modem" in settings.
- 92,041
