Whenever I try to install anything I get the following message:
Reading package lists... Done
Building dependency tree
You might want to run 'apt-get -f install' to correct these:
clang : Depends: clang-3.4 (>= 3.4~rc3-1~) but it is not going to be installed
linux-image-extra-3.16.0-52-generic : Depends: linux-image-3.16.0-52-generic but it is not going to be installed
linux-image-extra-3.16.0-57-generic : Depends: linux-image-3.16.0-57-generic but it is not going to be installed
linux-image-generic-lts-utopic : Depends: linux-image-3.16.0-57-generic but it is not going to be installed
E: Unmet dependencies. Try 'apt-get -f install' with no packages (or specify a solution).
However, when I run sudo apt-get -f install, I get this
Correcting dependencies... Done
The following packages were automatically installed and are no longer required:
erlang-asn1 erlang-base erlang-corba erlang-crypto erlang-diameter
erlang-edoc erlang-eldap erlang-erl-docgen erlang-eunit erlang-ic
erlang-inets erlang-mnesia erlang-nox erlang-odbc erlang-os-mon
erlang-parsetools erlang-percept erlang-public-key erlang-runtime-tools
erlang-snmp erlang-ssh erlang-ssl erlang-syntax-tools erlang-tools
erlang-webtool erlang-xmerl libsctp1 linux-headers-3.16.0-30
linux-headers-3.16.0-30-generic linux-headers-3.16.0-41
linux-headers-3.16.0-41-generic linux-headers-3.16.0-43
linux-headers-3.16.0-43-generic linux-headers-3.16.0-45
linux-headers-3.16.0-45-generic linux-headers-3.16.0-48
linux-headers-3.16.0-48-generic linux-headers-3.16.0-51
linux-headers-3.16.0-51-generic linux-headers-3.16.0-52
linux-headers-3.16.0-52-generic linux-image-3.16.0-30-generic
linux-image-3.16.0-41-generic linux-image-3.16.0-43-generic
linux-image-3.16.0-45-generic linux-image-3.16.0-48-generic
linux-image-3.16.0-51-generic linux-image-3.16.0-52-generic
linux-image-extra-3.16.0-30-generic linux-image-extra-3.16.0-41-generic
linux-image-extra-3.16.0-43-generic linux-image-extra-3.16.0-45-generic
linux-image-extra-3.16.0-48-generic linux-image-extra-3.16.0-51-generic
linux-image-extra-3.16.0-52-generic lksctp-tools
Use 'apt-get autoremove' to remove them.
The following extra packages will be installed:
linux-image-3.16.0-52-generic linux-image-3.16.0-57-generic
Suggested packages:
fdutils linux-lts-utopic-tools
The following NEW packages will be installed:
0 upgraded, 2 newly installed, 0 to remove and 295 not upgraded.
10 not fully installed or removed.
Need to get 0 B/32.4 MB of archives.
After this operation, 90.2 MB of additional disk space will be used.
Do you want to continue? [Y/n] y
(Reading database ... 478639 files and directories currently installed.)
Preparing to unpack .../linux-image-3.16.0-57-generic_3.16.0-57.77~14.04.1_amd64.deb ...
Done.
Unpacking linux-image-3.16.0-57-generic (3.16.0-57.77~14.04.1) ...
dpkg: error processing archive /var/cache/apt/archives/linux-image-3.16.0-57-generic_3.16.0-57.77~14.04.1_amd64.deb (--unpack):
cannot copy extracted data for './boot/abi-3.16.0-57-generic' to '/boot/abi-3.16.0-57-generic.dpkg-new': failed to write (No space left on device)
No apport report written because the error message indicates a disk full error
dpkg-deb: error: subprocess paste was killed by signal (Broken pipe)
Examining /etc/kernel/postrm.d .
run-parts: executing /etc/kernel/postrm.d/initramfs-tools 3.16.0-57-generic /boot/vmlinuz-3.16.0-57-generic
run-parts: executing /etc/kernel/postrm.d/zz-update-grub 3.16.0-57-generic /boot/vmlinuz-3.16.0-57-generic
Preparing to unpack .../linux-image-3.16.0-52-generic_3.16.0-52.71~14.04.1_amd64.deb ...
Done.
Unpacking linux-image-3.16.0-52-generic (3.16.0-52.71~14.04.1) ...
dpkg: error processing archive /var/cache/apt/archives/linux-image-3.16.0-52-generic_3.16.0-52.71~14.04.1_amd64.deb (--unpack):
cannot copy extracted data for './boot/vmlinuz-3.16.0-52-generic' to '/boot/vmlinuz-3.16.0-52-generic.dpkg-new': failed to write (No space left on device)
run-parts: executing /etc/kernel/postrm.d/initramfs-tools 3.16.0-52-generic /boot/vmlinuz-3.16.0-52-generic
run-parts: executing /etc/kernel/postrm.d/zz-update-grub 3.16.0-52-generic /boot/vmlinuz-3.16.0-52-generic
My boot partition is almost full (98,7%), and it has quite a few images, but I can't remove them because I get the same message then.
~$ ls /boot
abi-3.16.0-30-generic initrd.img-3.16.0-46-generic
abi-3.16.0-41-generic lost+found
abi-3.16.0-43-generic memtest86+.bin
abi-3.16.0-45-generic memtest86+.elf
abi-3.16.0-46-generic memtest86+_multiboot.bin
abi-3.16.0-48-generic System.map-3.16.0-30-generic
abi-3.16.0-49-generic System.map-3.16.0-41-generic
abi-3.16.0-51-generic System.map-3.16.0-43-generic
config-3.16.0-30-generic System.map-3.16.0-45-generic
config-3.16.0-41-generic System.map-3.16.0-46-generic
config-3.16.0-43-generic System.map-3.16.0-48-generic
config-3.16.0-45-generic System.map-3.16.0-49-generic
config-3.16.0-46-generic System.map-3.16.0-51-generic
config-3.16.0-48-generic vmlinuz-3.16.0-30-generic
config-3.16.0-49-generic vmlinuz-3.16.0-41-generic
config-3.16.0-51-generic vmlinuz-3.16.0-43-generic
grub vmlinuz-3.16.0-45-generic
initrd.img-3.16.0-30-generic vmlinuz-3.16.0-46-generic
initrd.img-3.16.0-41-generic vmlinuz-3.16.0-48-generic
initrd.img-3.16.0-43-generic vmlinuz-3.16.0-49-generic
initrd.img-3.16.0-45-generic vmlinuz-3.16.0-51-generic
