I'm running Ubuntu 14.04.4 LTS, and I'm trying to install a new package using apt-get. Unfortunately, whenever I try I get messages like:
 linux-image-extra-3.16.0-70-generic : Depends: linux-image-3.16.0-70-generic but it is not going to be installed
 linux-image-generic-lts-utopic : Depends: linux-image-3.16.0-70-generic but it is not going to be installed
 linux-signed-image-3.16.0-70-generic : Depends: linux-image-3.16.0-70-generic (= 3.16.0-70.90~14.04.1) but it is not going to be installed
Doing some googling, I found that this can be caused by lack of space on the boot partition (and sure enough, df shows /boot at 100%). However, any time I try running the apt-get commands in the accepted answer there, I get the same errors as above.
Looking for another solution that didn't use apt-get, I came across this post, which recommends using things like sudo dpkg --purge linux-image-4.2.0-15-generic on old, unused kernels.
dpkg -l | tail -n +6 | grep -E 'linux-image-[0-9]+' | grep -Fv $(uname -r) (from the afore-mentioned post) shows that I have several old kernels in the pi state (desired purged, state is installed according to this)
uname -r tells me the kernel I'm running is 3.16.0-62-generic, so I thought I should be safe to remove these old kernels. However, trying to do so with things like sudo dpkg --purge linux-image-3.16.0-49-generic results in:
dpkg: error processing package linux-image-3.16.0-49-generic (--purge):
 dependency problems - not removing
Garrg! I'm at my wit's end, and out of my depth (don't really know much about dpkg or apt-get), so I need some help.
Questions:
  1. Why can't I uninstall the old kernels with dpkg?
  2. If that question can't be directly solved, I guess ultimately I want to know: What do I need to do to get into a state where I can install new packages again?
Other things I have tried:
  • sudo apt-get autoremove : results in the original error about unmet dependencies
  • sudo apt-get -f autoremove : results in:
Unpacking linux-image-3.16.0-70-generic (3.16.0-70.90~14.04.1) ...
dpkg: error processing archive /var/cache/apt/archives/linux-image-3.16.0-70-generic_3.16.0-70.90~14.04.1_amd64.deb (--unpack):
 cannot copy extracted data for './boot/vmlinuz-3.16.0-70-generic' to '/boot/vmlinuz-3.16.0-70-generic.dpkg-new': failed to write (No space left on device)
No apport report written because the error message indicates a disk full error
        dpkg-deb: error: subprocess paste was killed by signal (Broken pipe)
Examining /etc/kernel/postrm.d .
run-parts: executing /etc/kernel/postrm.d/initramfs-tools 3.16.0-70-generic /boot/vmlinuz-3.16.0-70-generic
run-parts: executing /etc/kernel/postrm.d/zz-update-grub 3.16.0-70-generic /boot/vmlinuz-3.16.0-70-generic
Note: I've migrated this question from "Unix & Linux Stack Exchange"
augray
  • 163
Use uname -r to show your currently running kernel. DO NOT DELETE anything with this version number.
You can find which packages the kernels in /boot belong to:
for i in /boot/vmlinuz* ; do
    dpkg -S $i| egrep -v $(uname -r)
done
You can remove these packages with sudo apt-get purge packagename ....
You can find more packages related to the kernels to be deleted by looking for other packages with the same version number:
To extract the version numbers:
    dpkg -S $i | egrep -v $(uname -r)
done |cut -d- -f3-4
To find other packages with the same version numbers:
for j in $(
    done |cut -d- -f3-4 ) ;
do
     dpkg -l "*$j*" | egrep '^ii|^rc'
done
To automate deleting all kernels other than the current kernel, and all packages whose versions match the deleted kernels (Danger, Wil Robinson):
Simply append
| awk '{print $2}' | xargs sudo apt-get --dry-run purge
to the previous code fragment. WHen you're sure it does what you want, remove --dry-run.
If your /boot is so full that you cannot delete packages, you can make some space on /boot by removing the oldest /boot/initrd.img* file,
waltinator
  • 37,856
