I am trying to install the linux-image-extra-* packages, (which are a prerequisite for Docker) following the instructions here.
sudo apt-get install linux-image-extra-$(uname -r) linux-image-extra-virtual
But i get the following error message:
Reading package lists... Done
Building dependency tree
linux-image-extra-3.19.0-32-generic is already the newest version.
linux-image-extra-virtual : Depends: linux-image-generic (= 3.13.0.107.115) but it is not going to be installed
I tried fixing any broken dependencies using the following command:
sudo apt-get -f install
Which gives me the following output:
0 to upgrade, 0 to newly install, 0 to remove and 152 not to upgrade.
And then ran the command to install the linux-image-extra-* kernel packages, but i still get the same error.
I tried sudo apt-get update followed by the command to install the linux-image-extra-* kernel packages, but the same thing still.
What could the issue be? And how do i resolve it?
My system:
Ubuntu 14.04
The output of uname -r is:
3.19.0-32-generic
The output of dpkg --list | egrep -i --color 'linux-image|linux-headers' is
ii linux-headers-3.19.0-32 3.19.0-32.37~14.04.1 all Header files related to Linux kernel version 3.19.0
ii linux-headers-3.19.0-32-generic 3.19.0-32.37~14.04.1 amd64 Linux kernel headers for version 3.19.0 on 64 bit x86 SMP
ii linux-image-3.19.0-32-generic 3.19.0-32.37~14.04.1 amd64 Linux kernel image for version 3.19.0 on 64 bit x86 SMP
ii linux-image-extra-3.19.0-32-generic 3.19.0-32.37~14.04.1 amd64 Linux kernel extra modules for version 3.19.0 on 64 bit x86 SMP
Similar but not actually related posts
- This one had similar errors, but was an issue with too many items in boot partition, which doesn't appear to be the case for me.
Potential Solutions?
- I came accross this post which might be worth a try? It involves removing any lines of code related to the relevant package from the
dpkg statusfile. But I am worried that removing kernel image information from this file might break my computer.
