I am on ubuntu 14.04 and I accidentally deleted python3.4
I am trying
apt-get install python3.4
dpkg-reconfigure -a
apt-get install -f
But I am seeing the following errors
dpkg: error processing package dh-python (--configure):
 dependency problems - leaving unconfigured
 python3.4-minimal
 python3-minimal
 python3.4
 python3
 python3-pkg-resources
 python-chardet-whl
 python-pip-whl
 python3-chardet
 python3-colorama
 python3.4-dev
 python3-dev
 python3-distlib
 python3-six
 python3-html5lib
 python3-urllib3
 python3-requests
 python3-setuptools
 python3-pip
 python3-wheel
 dh-python
I also tried to completely remove python3.4 using
apt-get remove --purge python3.4
and reinstalling. but it gives me the following errors
Rebuilding /usr/share/applications/bamf-2.index...
Setting up python3.4-minimal (3.4.3-1ubuntu1~14.04.3) ...
Could not find platform independent libraries <prefix>
Consider setting $PYTHONHOME to <prefix>[:<exec_prefix>]
Fatal Python error: Py_Initialize: Unable to get the locale encoding
ImportError: No module named 'encodings'
Aborted
dpkg: error processing package python3.4-minimal (--configure):
 subprocess installed post-installation script returned error exit status 134
dpkg: dependency problems prevent configuration of python3.4:
 python3.4 depends on python3.4-minimal (= 3.4.3-1ubuntu1~14.04.3); however:
  Package python3.4-minimal is not configured yet.
dpkg: error processing package python3.4 (--configure):
 python3.4-minimal
 python3.4
Can anyone help me with this?
output for @Nodak 's answer:
Aborted
dpkg: dependency problems prevent configuration of python3-minimal:
 python3-minimal depends on python3.4-minimal (>= 3.4.0-0~); however:
dpkg: error processing package python3-minimal (--configure):
dpkg: dependency problems prevent configuration of python3:
 python3 depends on python3.4 (>= 3.4.0-0~); however:
  Package python3.4 is not configured yet.
 python3 depends on python3-minimal (= 3.4.0-0ubuntu2); however:
  Package python3-minimal is not configured yet.
dpkg: error processing package python3 (--configure):
dpkg: dependency problems prevent configuration of dh-python:
 dh-python depends on python3:any (>= 3.3.2-2~); however:
  Package python3 is not configured yet.
 python3.4-minimal
 python3.4
 python3-minimal
 python3
 dh-python
This is the output when I run dpkg-reconfigure -a
dpkg-reconfigure -a
acpid stop/waiting
acpid start/running, process 26874
avahi-daemon stop/waiting
avahi-daemon start/running, process 27149
update-alternatives: using /usr/share/man/man7/bash-builtins.7.gz to provide /usr/share/man/man7/builtins.7.gz (builtins.7.gz) in auto mode
update-initramfs: deferring update (trigger activated)
cgroup-lite stop/waiting
cgroup-lite start/running
/var/lib/dpkg/info/compiz.config: 1: /var/lib/dpkg/info/compiz.config: [general]: not found
/var/lib/dpkg/info/compiz.config: 2: /var/lib/dpkg/info/compiz.config: backend: not found
/var/lib/dpkg/info/compiz.config: 3: /var/lib/dpkg/info/compiz.config: plugin_list_autosort: not found
/var/lib/dpkg/info/compiz.config: 5: /var/lib/dpkg/info/compiz.config: [gnome_session]: not found
/var/lib/dpkg/info/compiz.config: 6: /var/lib/dpkg/info/compiz.config: backend: not found
/var/lib/dpkg/info/compiz.config: 7: /var/lib/dpkg/info/compiz.config: integration: not found
/var/lib/dpkg/info/compiz.config: 8: /var/lib/dpkg/info/compiz.config: plugin_list_autosort: not found
/var/lib/dpkg/info/compiz.config: 9: /var/lib/dpkg/info/compiz.config: profile: not found
/var/lib/dpkg/info/compiz.config: 11: /var/lib/dpkg/info/compiz.config: [general_ubuntu]: not found
/var/lib/dpkg/info/compiz.config: 12: /var/lib/dpkg/info/compiz.config: backend: not found
/var/lib/dpkg/info/compiz.config: 13: /var/lib/dpkg/info/compiz.config: integration: not found
/var/lib/dpkg/info/compiz.config: 14: /var/lib/dpkg/info/compiz.config: plugin_list_autosort: not found
/var/lib/dpkg/info/compiz.config: 15: /var/lib/dpkg/info/compiz.config: profile: not found
Try fully uninstalling python by running
sudo apt-get remove --purge python3.4
This will remove all dependencys installed with python
Then install python again by running
sudo apt-get install python3.4
Hope this helped,
Zimbinskers
So try installing just python not the specific version 3.4. There may be an issue with dependencys not properly being installed. So just run
And tell me the results.
Hope this helps,
Zimbinskers
It is a mystery.
I deleted /usr/lib/python3.4 then I sudo apt-get purge -f python3
(if you try this you might want a list of your packages to re-install those packages that are Python3 dependent and subsequently removed by apt-get magic.
Instructions how to do this
I then went to reinstall python3 sudo apt-get install -f python3. It failed.
sudo apt-get -f install was issued and a number of packages were installed.
Reissueing sudo apt-get install -f python3 succeeded in restoring the directory usr/lib/python3.4 and Python 3 functionality.
I reinstalled the packages lost as collateral damage.
Nodak
  • 690
