(This is not a duplicate of Accidentally deleted /usr/lib/python3.4, the errors I get are different.)
Today I accidentally deleted usr/lib/python3.4, now Ctrl+Alt+T is not working anymore, terminal and unity-tweak-tool are not opening from the app drawer.
I get this error while I try to open unity-tweak-tool from the terminal. How can I fix this?
Could not find platform independent libraries
Could not find platform dependent libraries
Consider setting $PYTHONHOME to [:]
Fatal Python error: Py_Initialize: Unable to get the locale encoding
ImportError: No module named 'encodings'
UPDATE
After running sudo apt install --reinstall $(dpkg -S /usr/lib/python3.* | sed -r 's/, /\n/g; s/\: .+//') it reinstalled some things but at the end it gave me another error: E: Internal Error, No file name for python3.4:amd64. After running unity-tweak-tool I now get:
Could not find platform independent libraries <prefix>
Consider setting $PYTHONHOME to <prefix>[:<exec_prefix>]
Current thread 0x00007f06bc180700 (most recent call first):
(core dump created)
ZwartyZ
  • 101
Several Python packages keep their in there so reinstalling one might not do it. See what has files in there on your system by running:
dpkg -S /usr/lib/python3.4
That will return something slightly different for everybody but the important part is reinstalling the packages it shows.
It needs a bit of processing (removing commas, chopping off the path), but here's something that does all that and gets them reinstalled.
In some cases you might have to prioritise (install them first) some packages over others manually but see what you get.
Oli
  • 299,380
