I just installed Ubuntu 14.04.3 LTS Kernel Version 3.19.0-39-generic.
I can connect to the internet with Ethernet cable. When I switch to a fixed-ip wireless network, the computer freezes!
I have the wireless card BCM43227 from Broadcom. I thought it might be a driver problem so I did the following (since apparently Broadcom drivers are a bit buggy):
sudo apt-get purge bcmwl-kernel-source broadcom-sta-common broadcom-sta-source
sudo apt-get install b43-fwcutter firmware-b43-installer
But it didn't work.
I've googled a lot and found that there were similar bugs (https://bugs.launchpad.net/ubuntu/+source/network-manager/+bug/1464738, Freeze after upgrading kernel to 3.13.0-66 (14.04) or 3.19.0-31 (15.04)) recently which might be fixed (https://bugs.launchpad.net/ubuntu/+source/linux/+bug/1503647/comments/7).
Some of these bugs come from the proposed repositories, which I DO NOT have activated. Is this issue still a bug? or a wrong driver?
Any help will be appreciated :-)
Edit 1: output from lspci -knn | grep Net -A2
02:00.0 Network controller [0280]: Broadcom Corporation BCM43227 802.11b/g/n [14e4:4358]
Subsystem: Foxconn International, Inc. Device [105b:e040]
Kernel driver in use: bcma-pci-bridge
Edit 2: tried solution from possible duplicate Installing Broadcom Wireless Drivers
which means running the command
sudo apt-get install bcmwl-kernel-source
Unfortunately, it did not work. The system froze once again after connecting with the wireless network.
Note: this was the same driver that was installed after the fresh install that I did a few hours ago, or at least that's what I think since the system settings->software updates->additional drivers said I was using the proprietary drivers.
Edit 3:
After boot up, both the cable and wireless connection are connected. No system freeze.
Unplugged Ethernet cable, wireless connection still active. No system freeze.
The moment I tried to open the browser -->> system froze! :-(
I don't know what that means ... any thoughts?
Edit 4: the log cat /var/log/syslog | grep -i network | tail -n25
This is all I can get before the system freezes (unpluged Eth-Cable and browser was open):
Dec 8 09:03:37 aguilar NetworkManager[996]: <info> Config: set interface ap_scan to 1
Dec 8 09:03:37 aguilar NetworkManager[996]: <info> (eth0): device state change: activated -> unavailable (reason 'carrier-changed')
Dec 8 09:03:37 aguilar NetworkManager[996]: <info> (eth0): deactivating device (reason 'carrier changed')
Dec 8 09:03:37 aguilar NetworkManager[996]: <warn> DNS: plugin dnsmasq update failed
Dec 8 09:03:37 aguilar NetworkManager[996]: <info> Removing DNS information from /sbin/resolvconf
Dec 8 09:03:37 aguilar NetworkManager[996]: <info> NetworkManager state is now CONNECTING
Dec 8 09:03:37 aguilar NetworkManager[996]: <info> (wlan0): supplicant interface state: inactive -> scanning
Dec 8 09:03:44 aguilar NetworkManager[996]: <info> (wlan0): supplicant interface state: scanning -> associating
Dec 8 09:03:44 aguilar NetworkManager[996]: <info> (wlan0): supplicant interface state: associating -> 4-way handshake
Dec 8 09:03:44 aguilar NetworkManager[996]: <info> (wlan0): supplicant interface state: 4-way handshake -> completed
Dec 8 09:03:44 aguilar NetworkManager[996]: <info> Activation (wlan0/wireless) Stage 2 of 5 (Device Configure) successful. Connected to wireless network 'GOE-WLAN'.
Dec 8 09:03:44 aguilar NetworkManager[996]: <info> Activation (wlan0) Stage 3 of 5 (IP Configure Start) scheduled.
Dec 8 09:03:44 aguilar NetworkManager[996]: <info> Activation (wlan0) Stage 3 of 5 (IP Configure Start) started...
Dec 8 09:03:44 aguilar NetworkManager[996]: <info> (wlan0): device state change: config -> ip-config (reason 'none') [50 70 0]
Dec 8 09:03:44 aguilar NetworkManager[996]: <info> Activation (wlan0) Stage 5 of 5 (IPv4 Configure Commit) scheduled...
Dec 8 09:03:44 aguilar NetworkManager[996]: <info> Activation (wlan0) Beginning IP6 addrconf.
Dec 8 09:03:44 aguilar NetworkManager[996]: <info> Activation (wlan0) Stage 3 of 5 (IP Configure Start) complete.
Dec 8 09:03:44 aguilar NetworkManager[996]: <info> Activation (wlan0) Stage 5 of 5 (IPv4 Commit) started...
Dec 8 09:03:45 aguilar NetworkManager[996]: <info> (wlan0): device state change: ip-config -> secondaries (reason 'none') [70 90 0]
Dec 8 09:03:45 aguilar NetworkManager[996]: <info> Activation (wlan0) Stage 5 of 5 (IPv4 Commit) complete.
Dec 8 09:03:45 aguilar NetworkManager[996]: <info> (wlan0): device state change: secondaries -> activated (reason 'none') [90 100 0]
Dec 8 09:03:45 aguilar NetworkManager[996]: <info> NetworkManager statte is now CONNECTED_GLOBAL
Dec 8 09:03:45 aguilar NetworkManager[996]: <info> Policy set 'GOE-WLAN' (wlan0) as default for IPv4 routing and DNS
Dec 8 09:03:45 aguilar NetworkManager[996]: <info> Writing DNS information to /sbin/resolvconf
Dec 8 09:03:46 aguilar NetworkManager[996]: <info> Activation (wlan0) successful, device activated
Log after boot up and before I open my browser:
Dec 8 09:07:11 aguilar NetworkManager[838]: <info> (wlan0): supplicant interface state: 4-way handshake -> completed
Dec 8 09:07:11 aguilar NetworkManager[838]: <info> Activation (wlan0/wireless) Stage 2 of 5 (Device Configure) successful. Connected to wireless network 'GOE-WLAN'.
Dec 8 09:07:11 aguilar NetworkManager[838]: <info> Activation (wlan0) Stage 3 of 5 (IP Configure Start) scheduled.
Dec 8 09:07:11 aguilar NetworkManager[838]: <info> Activation (wlan0) Stage 3 of 5 (IP Configure Start) started...
Dec 8 09:07:11 aguilar NetworkManager[838]: <info> (wlan0): device state change: config -> ip-config (reason 'none') [50 70 0]
Dec 8 09:07:11 aguilar NetworkManager[838]: <info> Activation (wlan0) Stage 5 of 5 (IPv4 Configure Commit) scheduled...
Dec 8 09:07:11 aguilar NetworkManager[838]: <info> Activation (wlan0) Beginning IP6 addrconf.
Dec 8 09:07:11 aguilar NetworkManager[838]: <info> Activation (wlan0) Stage 3 of 5 (IP Configure Start) complete.
Dec 8 09:07:11 aguilar NetworkManager[838]: <info> Activation (wlan0) Stage 5 of 5 (IPv4 Commit) started...
Dec 8 09:07:12 aguilar NetworkManager[838]: <info> (wlan0): device state change: ip-config -> secondaries (reason 'none') [70 90 0]
Dec 8 09:07:12 aguilar NetworkManager[838]: <info> Activation (wlan0) Stage 5 of 5 (IPv4 Commit) complete.
Dec 8 09:07:12 aguilar NetworkManager[838]: <warn> error monitoring device for netlink events: error processing netlink message: Object busy
Dec 8 09:07:12 aguilar NetworkManager[838]: <info> (wlan0): device state change: secondaries -> activated (reason 'none') [90 100 0]
Dec 8 09:07:13 aguilar NetworkManager[838]: <info> Writing DNS information to /sbin/resolvconf
Dec 8 09:07:13 aguilar NetworkManager[838]: <info> Activation (wlan0) successful, device activated.
Dec 8 09:07:12 aguilar NetworkManager[838]: <info> WiFi hardware radio set enabled
Dec 8 09:07:23 aguilar NetworkManager[838]: <warn> error monitoring device for netlink events: error processing netlink message: Object busy
Dec 8 09:07:24 aguilar NetworkManager[838]: <info> (eth0): IP6 addrconf timed out or failed.
Dec 8 09:07:24 aguilar NetworkManager[838]: <info> Activation (eth0) Stage 4 of 5 (IPv6 Configure Timeout) scheduled...
Dec 8 09:07:24 aguilar NetworkManager[838]: <info> Activation (eth0) Stage 4 of 5 (IPv6 Configure Timeout) started...
Dec 8 09:07:24 aguilar NetworkManager[838]: <info> Activation (eth0) Stage 4 of 5 (IPv6 Configure Timeout) complete.
Dec 8 09:07:30 aguilar NetworkManager[838]: <info> (wlan0): IP6 addrconf timed out or failed.
Dec 8 09:07:30 aguilar NetworkManager[838]: <info> Activation (wlan0) Stage 4 of 5 (IPv6 Configure Timeout) scheduled...
Dec 8 09:07:30 aguilar NetworkManager[838]: <info> Activation (wlan0) Stage 4 of 5 (IPv6 Configure Timeout) started...
Dec 8 09:07:30 aguilar NetworkManager[838]: <info> Activation (wlan0) Stage 4 of 5 (IPv6 Configure Timeout) complete.
