I do not have a flash drive or a CD that I can burn, what are some other ways that I could install Ubuntu on my computer (dell latitude d620)?
Asked
Active
Viewed 448 times
In case you have a running Ubuntu system ... You can add the Ubuntu install ISO file to the GRUB boot menu and install Ubuntu without having to create an installation media (DVD or USB drive).
Open a terminal and execute :
sudo apt-get install gksu
gksudo gedit /etc/grub.d/40_custom
Insert the following into the file :
menuentry "ubuntu install media" {
set isofile="/…/XXX.iso"
loopback loop (hdX,XX)$isofile
linux (loop)/casper/vmlinuz.efi boot=casper iso-scan/filename=$isofile noprompt noeject toram
initrd (loop)/casper/initrd.lz
Note : ... = ISO file path | X = disk | XX = partition | XXX = ISO file name )
Save the file and execute :
sudo update-grub
Now reboot - choose the new entry from the GRUB boot menu and proceed installation as usual.
You will find some alternatives here -> Is it possible to install Ubuntu without a CD or USB drive ?
