14
So basically as it stands I have a laptop which has no cd/dvd drive, and I don't have a usb drive.
The laptop has windows 7 installed with ubuntu 11.04 installed through wubi.
What I want to do is remove windows completely, and make ubuntu the only OS installed on the system.
Is there a way to do this without re-installing ubuntu? (i.e. can I take my wubi install away from windows?)
or is there a way to from inside ubuntu have it run the ubuntu iso somehow so I can just wipe the system and install it fresh? (even if it means I need to have an e.g. 2gb partition just for the image to reside in).
Braiam
  • 69,112
Hailwood
  • 5,017
15 Answers15
13
Yep, all your friend needs to do is download and install Wubi. It's designed for this exact scenario. You can check it out here: http://wubi-installer.org/
Jason
  • 185
10
  1. Use Windows 7 to shrink one of your partitions (you can shrink a mounted partition while running Windows). If you already have 4 primary partitions you'll need to remove one of them first.
  2. Boot wubi and install GParted and create an extended partition in the free space you created, and then 2 logical partitions, one an ext4 partition large enough to contain your Wubi install, and optionally 1 swap partition (> size of RAM).
  3. Migrate wubi to the partition, installing the grub bootloader at the same time
  4. Boot the migrated Ubuntu and format the Windows partition, which you can then reuse as a separate /home or you can use the same migration script to move the migrated Ubuntu to it.
This solution doesn't require a live CD/USB (although it's always a good idea to have one.
bcbc
  • 6,036
If you have a USB Flash drive of 1GB or more you can use the following method.
What You Will Need
  1. You'll need to download the Universal USB Installer.
  2. Download your chosen Ubuntu ISO Image from Here.
  3. A USB Flash Drive with 1GB or more of available free space.
The Process
  1. Download the Universal USB Installer...
  2. Download your Ubuntu/Linux ISO of choice.
  3. Open up the Universal USB Installer program and select your Linux ISO from the list.
  4. After selecting your Linux ISO select the name of the drive you wish to write the Ubuntu program to. NOTE: This process will completely remove ALL data from your drive when writing the Ubuntu Program to it so make sure it's the one you want to use!!!
  5. After the process completes turn off your pc, stick in the Live USB that you just made, then turn your pc back on, and then select the USB Drive from your boot menu. After that you can either test Ubuntu on your machine or install it!
  6. Enjoy your new Ubuntu installation!
If you wish to create a flash drive that is persistent (I.E. You can save stuff to it like files and settings etc...) might I suggest that you take a look at the following question and it's subsequent answers? Method to create a live USB disk (with persistence) which actually works?
Hopes this helps you out!!!
zkriesse
  • 1,425
The Ubuntu Help Wiki has a section on Installation Without a CD with sections like from USB, Windows, Linux, VM, etc.
Umang
  • 6,733
You have to use alternative cd
  1. First Download the Alternative cd iso using torrent from this link.
  2. Either mount or burn the iso to usb (using startup disk creator).
  3. A dialog will be displayed offering you the opportunity to upgrade.
  4. Follow the on-screen instructions.
Anwar
  • 77,855
Lincity
  • 25,749
If your laptop supports it, you should be able to do a net install using PXE. Most laptops will allow you to "boot from the network" at startup. You might have to hit ESC or something like that during boot to get in the right menu.
This does require you to do a bit of setup on another machine in your network, which will serve the Ubuntu installation media. See https://help.ubuntu.com/community/PXEInstallServer
jelmer
  • 2,156
Please make a backup before testing this because I'm not 100% sure it will work flawless.
I think the way to do it is something like this (untested):
  1. Format one partition that will be your destination for the installation (I suggest you to choose the ext4 format)
  2. Copy the your files and folders from wubi to the new partition
  3. Make sure you have a folder named /boot/ with at least two files like initrd.img-2.6.38-10-generic and vmlinuz-2.6.38-10-generic
  4. Than you will have to install grub:
These instructions were adapted from: https://wiki.ubuntu.com/Grub2#Recover
"METHOD 3 - CHROOT
This method of installation uses the chroot command to gain access to the broken system's files. Once the chroot command is issued, the LiveCD (in your case the wubi installation) treats the broken system's / as its own. Commands run in a chroot environment will affect the broken systems filesystems and not those of the LiveCD.
1) Boot to the LiveCD Desktop (Ubuntu 9.10 or later) (Open Ubuntu at Wubi). Please note that the Live CD must be the same as the system you are fixing - either 32-bit or 64-bit (if not then the chroot will fail).
2) Open a terminal - Applications, Accessories, Terminal. 3) Determine your normal system partition - (the switch is a lowercase "L")
sudo fdisk -l
If you aren't sure, run
df -Th
Look for the correct disk size and ext3 or ext4 format.
4) Mount your normal system partition:
Substitute the correct partition: sda1, sdb5, etc.
sudo mount /dev/sdXX /mnt
# Example: sudo mount /dev/sda1 /mnt
5) Only if you have a separate boot partition: sdYY is the /boot partition designation (for example sdb3)
sudo mount /dev/sdYY /mnt/boot
6) Mount the critical virtual filesystems:
sudo mount --bind /dev  /mnt/dev
sudo mount --bind /dev/pts  /mnt/dev/pts
sudo mount --bind /proc /mnt/proc
sudo mount --bind /sys  /mnt/sys
7) Chroot into your normal system device:
sudo chroot /mnt
8) If there is no /boot/grub/grub.cfg or it's not correct, create one using
update-grub
9) Reinstall GRUB 2:
Substitute the correct device - sda, sdb, etc. Do not specify a partition number.
grub-install /dev/sdX
10) Verify the install (use the correct device, for example sda. Do not specify a partition):
sudo grub-install --recheck /dev/sdX
11) Exit chroot: CTRL-D on keyboard 12) Unmount virtual filesystems:
sudo umount /mnt/dev/pts
sudo umount /mnt/proc
sudo umount /mnt/sys
13) If you mounted a separate /boot partition:
sudo umount /mnt/boot
14) Unmount the LiveCD's /usr directory:
sudo umount /mnt/usr
15) Unmount last device:
sudo umount /mnt
16) Reboot.
sudo reboot
desgua
  • 33,215
UNetbootin:
UNetbootin allows you to create bootable Live USB drives for Ubuntu, Fedora, and other Linux distributions without burning a CD. It runs on Windows, Linux, and Mac OS X. You can either let UNetbootin download one of the many distributions supported out-of-the-box for you, or supply your own Linux .iso file if you've already downloaded one or your preferred distribution isn't on the list.
UNetbootin can make a "frugal install" on your local hard disk if you don't have a USB drive. For the Hard-Disk/ "frugal install" mode, UNetbootin uses a Linux-based installer to install a small modification to the bootloader to boot the desired distribution's installer or to load the system utility, no CD required. After the distribution has been installed, or once done using the system utility, the modification to the bootloader is then undone.
You can use the following link to run the "frugal/hard-disk install":
https://sourceforge.net/p/unetbootin/wiki/installmodes/
13east
  • 1,945
If you have an Ethernet connection to the machine, and it supports it, you may be able to network boot/install. That is, use the drive on another machine to install Ubuntu over your local network.
Check out the Ubuntu community doc for it over here.
Edit: Wow, jelmer, beat me to it while I was typing.
Gray
  • 179
I once installed an Ubuntu derivative(Samurai) using Virtualbox to mount my harddisk raw partition as a virtualbox hard drive. It involves creating a vmdk file which is linked to the partition. Then anything you do on the virtualbox goes to the partition. Even the grub install worked.
However, this method is quite risky as it involves giving raw access to Virtualbox. Further you can,quite simply try to boot into Windows twice (the second time inside your VirtualBox), so it is not recommended. But it is always an option to install it, and just delete the Virtual Machine. However your boot structure, partition should still retain your brand new Ubuntu install.
Here's the link I used : Accessing Physical Disks on Virtualbox
Nemo
  • 9,610
He could setup a live CD ISO for PXE boot, or use one that is available on the net.
See Netbooting Ubuntu Live CDs.
txwikinger
  • 29,406
Well, theoretically, if you already have more than one partition on your disk or some unallocated space, you could boot Ubuntu using wubi, create a new partition from there, install Ubuntu on that partition, reboot, remove the Windows partition.
The point is - you can't modify partitions or install Ubuntu on a partition you booted from, so you need more than one. Wubi does not count as a separate partition - it resides on the Windows partition so you can't touch that.
But, honestly, USB drives are very-very cheap these days - make a small investment and save you some time :)
Sergey
  • 44,353
He can download and install wubi which doesn't require a usb or cd key. Here is a link.
Here is also another link on the various way ubuntu can be installed.
myusuf3
  • 35,659
You could use Unetbootin and set it to use the hard drive.
Wubi will allow you to install Ubuntu while keeping Windows installed. If at anytime he decides he does not like Ubuntu he can uninstall it just like a normal program and it will give him his space back. If he does any other install it will be much harder to uninstall. He'll have to use the Disk Management tool and delete the partition and then extend the Windows partition. In order to get Wubi you can download it at http://wubi-installer.org/ or download the current Ubuntu release and then use 7-Zip to extract the ISO and then click on wubi.exe. An installer should appear and he can follow the instructions from there. It's very simple for even the most non-tech users.
Cody Harlow
  • 1,482
