14
After a fresh install on a brand new HP Probook 470 G3 everything is working perfect only sound :-( Try to re-install all alsa parts, but still no sound.
If the manual is correct it is a Conexant CX7501
Alsamixer is showing only spdif (3x) all on 0. I cannot select any other sound cards. It seems like I missing the (intel) drivers ?
alsa-info seems oke.. what do I miss ?
See also: http://www.alsa-project.org/db/?f=fd172ad3823bcaec1a8e2b6af031b394b986a466
This could be the problem:
dmesg | grep snd
[   12.349541] snd_hda_intel 0000:00:1f.3: enabling device (0000 -> 0002)
[   12.349681] snd_hda_intel 0000:00:1f.3: bound 0000:00:02.0 (ops i915_audio_component_bind_ops [i915])
[   15.383652] snd_hda_intel 0000:00:1f.3: azx_get_response timeout, switching to polling mode: last cmd=0x000f0000
[   16.395482] snd_hda_intel 0000:00:1f.3: No response from codec, disabling MSI: last cmd=0x000f0000
[   17.399551] snd_hda_intel 0000:00:1f.3: Codec #0 probe error; disabling it...
I have added acpi=off to grub:
GRUB_CMDLINE_LINUX_DEFAULT="quiet splash" acpi=off
update-grub
Installed pavucontrol
removed alsa-base.conf and reboot
added
options snd-hda-intel enable_msi=1
to /etc/modprobe.d/alsa-base.conf
Some extra info:
uname -a
Linux ProBook 4.2.0-18-generic #22-Ubuntu SMP Fri Nov 6 18:25:50 UTC 2015 x86_64 x86_64 x86_64 GNU/Linux
lspci -v | grep -A7 -i "audio"
00:1f.3 Audio device: Intel Corporation Device 9d70 (rev 21)
Subsystem: Hewlett-Packard Company Device 8102
Flags: bus master, fast devsel, latency 64, IRQ 16
Memory at c2420000 (64-bit, non-prefetchable) [size=16K]
Memory at c2410000 (64-bit, non-prefetchable) [size=64K]
Capabilities: [50] Power Management version 3
Capabilities: [60] MSI: Enable- Count=1/1 Maskable- 64bit+
Kernel driver in use: snd_hda_intel
lsmod | grep snd
snd_hda_intel          36864  0
snd_hda_codec         135168  1 snd_hda_intel
snd_hda_core           65536  2 snd_hda_codec,snd_hda_intel
snd_hwdep              16384  1 snd_hda_codec
snd_pcm               102400  3 snd_hda_codec,snd_hda_intel,snd_hda_core
snd_seq_midi           16384  0
snd_seq_midi_event     16384  1 snd_seq_midi
snd_rawmidi            32768  1 snd_seq_midi
snd_seq                69632  2 snd_seq_midi_event,snd_seq_midi
snd_seq_device         16384  3 snd_seq,snd_rawmidi,snd_seq_midi
snd_timer              32768  2 snd_pcm,snd_seq
snd                    81920  8      snd_hwdep,snd_timer,snd_pcm,snd_seq,snd_rawmidi,snd_hda_codec,snd_hda_intel,snd_seq_device
soundcore              16384  1 snd
Still no sound :-(
bas
  • 291
I found the solution (!), create a new file /etc/modprobe.d/intel.conf
add the following options:
options snd-hda-intel single_cmd=1
options snd-hda-intel probe_mask=1
reboot....
bas
  • 291
The solution works for Ubuntu 14.10 also! I have HP ProBook 470 G3, too.
Being new to linux, it took me some time to use the hint. This is the full set of commands; the first one creates, the second one edits the file.
sudo touch /etc/modprobe.d/intel.conf
sudo nano /etc/modprobe.d/intel.conf
Type the two options below in the editor, press ctrl+x to exit, type y to confirm and enter to confirm filename.
Then reboot.
