Probably this question has already been answered somewhere, but I could not find it.
The situation: I am on Ubuntu 15.10, on a laptop.
I have a secondary bluetooth speakers system, on which I redirect some output (mainly the music).
I can control the volume with pactl with
pactl -- set-sink-volume bluez_sink.00_18_91_65_D8_6D +5%
pactl -- set-sink-volume bluez_sink.00_18_91_65_D8_6D -5%
and having associated this to some keyboard shortcuts I can increase and decrease it like if it'd be local.
This works fine but, unlike for the main output (the internal audio card), using this command does not produce a notification with the actual volume level.
So, how can I produce the notification with the changing icon and the bar for the volume, like Ubuntu does?
Should I use notify-send? With which parameters?
It should not be a "normal" notification, because it has to "stick" there when the volume changes and just adapt the bar...
dadexix86
  • 6,776
Yep, it should be special notification:
gdbus call --session --dest org.freedesktop.Notifications \
  --object-path /org/freedesktop/Notifications \
  --method org.freedesktop.Notifications.Notify \
    'gnome-settings-daemon' \
    0 \
    'notification-audio-volume-medium' \
    "{'x-canonical-private-synchronous': <'volume'>, 'value': <24>}" \
  1. Found by watching dbus-monitor:
    method call time=1447796042.858910 sender=:1.11 -> destination=:1.96 serial=216 path=/org/freedesktop/Notifications; interface=org.freedesktop.Notifications; member=Notify
       string "gnome-settings-daemon"
       uint32 0
       string "notification-audio-volume-medium"
       string " "
       string ""
       array [
       array [
          dict entry(
             string "x-canonical-private-synchronous"
             variant             string "volume"
          dict entry(
             string "value"
             variant             int32 48
       int32 -1
  2. Then write my own call using:
  3. Icons available are:
    find /usr/share/notify-osd/icons/hicolor/scalable/status/ -name "notification-audio-volume-*" -exec basename {} .svg \;
    notification-audio-volume-low
    notification-audio-volume-off
    notification-audio-volume-muted
    notification-audio-volume-high
user.dz
  • 49,176
