I would like to configure and change some shortcut keys of Nautilus (file manager of Ubuntu). Does anyone know where I could do that?
Edit1: Precisely, initial binding for "go to parent folder" in Nautilus is Tab + Up arrow, I would like to chang it to Ctrl + Up arrow because Tab + Up arrow has already been set to other things via Compiz.
SoftTimur
  • 3,089
In Ubuntu 13.04 through 16.04 at least, the keyboard shortcuts for Nautilus are mapped in the "~/.config/nautilus/accels" file. Edit that file to change the mappings.
Elder Geek
  • 36,752
colan
  • 1,155
This Nautilus extension allows you to edit keyboard shortcuts (accelerators).
After installing the extensions go to Edit -> Keyboard Shortcuts... in the main menu and search for the Up action in the Keyboard Shortcuts dialog. Click the Key cell corresponding to this action and enter a shortcut:
Unlike the can_change_accels solution this will also work with Unity's global menus.
vitaut
  • 468
I assume, you mean the keys for something that can be found in nautilus' menu bar. First: This doesn't work if the global menu is on. Since you can't disable it for nautilus on a per-window basis (for nautilus is always running in the background), you should either log in to a non-unity-session (like gnome shell) or disable it for all windows. (Here is a guide how to disable it). You have to change a setting in gconf-editor (which might not yet be installed on your system, but can be found in software center). The key you need to enable is:
/desktop/gnome/interface/can_change_accels
Probably you need to log off and back on again to make this change take effect. Afterwards just point at the menu entry whose schortcut you want to change and press the desired keys. After all changes are done, you can turn on global menu again.
soulsource
  • 5,034
