I've recently upgraded from Ubuntu 16.04 to 18.04 and am working to get used to it. Coming from other environments, (possibly including the Unity GUI shell before it was retired from being the default) I'm very used to alt-D to move the cursor into the location-bar to jump to paths I can type directly. The current Nautilus (3.26.4) doesn't have an obvious way to enable this binding.
Though I have no reason to remove the ctrl-L shortcut, I'm looking for a way to have alt-D do the same thing, as I find it more natural to hit. Ideally, this could be done without replacing Nautilus, though I'm flexible if the answer would be "modify X, download a ton of dev-packages, and then recompile from source."
So, without having to abandon the (now-default) GNOME GUI shell, how can I do this?
Footnotes: I'm aware of the existing / and ~ shortcuts to begin typing paths from the root and home directories, but sometimes I want to modify the current path, rather than wipe it out, as those two do.
Sorry if this is a dumb question; I'm swimming here because it seems Canonical has moved and in some cases removed Nautilus options between practically all major versions.
I've already tried using dconf-editor /org/gnome/desktop/interface/can-change-accels to allow editing ~/.config/nautilus/accels in order to change the line starting with ; (gtk_accel_path "<Actions>/ShellActions/Enter Location" but apparently ~/.config/nautilus/accels is not honored anymore anyway.
Also from what I understand I don't think it will help to do anything with UBUNTU_MENUPROXY=0, since I believe there must be a GUI option to hover before a binding can be set.
References:
- Editing Nautilus shortcut keys 13.04 through 16.04
- No shortcuts file appears after Nautilus 3.22+ (?)
- Captain Nemo, which allowed editing shortcuts, is no longer supported due to removal of key Nautilus features (last update mid 2013)
- RobotMan/Devim adds a way to bind shortcuts to scripts in Nautilus!
