19
How can I set a shortcut for open terminal in current directory for nautilus?
I'm using Nautilus 3.16.2 and I already tried this answer but look like it's broken in newer version.
pazel1374
  • 679
I added a new feature to Nautilus with the precious help of the maintainers.
This new feature allow you to map custom keyboard shortcuts to launch the scripts in the scripts folder ( ~/.local/share/nautilus/scripts ).
So, when you add an executable in that folder it will appear in the right-click context menu, but now if you create a special configuration file ( ~/.config/nautilus/scripts-accels ) you can assign a shortcut to it. (Notice different file location: opposite to Terminal this one in .config, not .local/share)
For example make a script called Terminal with the following content:
#! /bin/sh
gnome-terminal
Now create (or edit) the ~/.config/nautilus/scripts-accels file adding the following lines:
F4 Terminal
; Commented lines must have a space after the semicolon ; Examples of other key combinations: ; <Control>F4 Terminal ; <Alt>F4 Terminal ; <Shift>F4 Terminal
Restart Nautilus (nautilus -q) and when you'll press F4 key you'll open a new terminal window in the current directory (feel free to create a new key combination following the commented lines examples).
Note: if you select one or more files, their names will be passed as parameters to the executable. Your script can also have access to many information through environment variables.
Link of the commit: https://git.gnome.org/browse/nautilus/commit/?id=9fe1335
There is also a gui to manage these shortcuts: https://github.com/echo-devim/nautilusaccelsmanager
Suggon
RobotMan
  • 381
According to News file inside nautilus git repository, since version 3.15.4 accells not loaded any more
Major changes in 3.15.4:
* Stop loading custom accel maps file
Fortunately for nautilus >= 3.20 "RobotMan" answer solved the problem.
pazel1374
  • 679
One option is to use:
Ctrl + F10 then e
Ctrl + F10: Same as right click at the current folder
e: Selects "Open in Terminal"
This is my favorite because you don't have to change any settings
It can change if your OS is in another language.
For example, in portuguese from brasil would be:
Ctrl + F10 then t
Just look at the underlined letter to know the key.
If you are using notebook you may have to use the super key too.
Ctrl + Super + F10 then e
