I'd like to change the keybindings in Nautilus. Specifically, I'd like to make it so Ctrl + Tab and Ctrl + Shift + Tab cycles between tabs instead of Ctrl+ PgUp / PgDn. I can't seem to find anything in dconf, and Nautilus only lists the shortcuts and doesn't let me change them. I tried using the solution here, but (1) the file ~/.config/nautilus/accels does not exist, so I can't figure out the syntax/lines I'm supposed to edit, and (2) making the file and copying their code into it didn't do anything. Any help is appreciated! Thanks!
- 61
You can, but it's not easy: The standard parameters of Nautilus do not allow you to change these keybindings as there are no configuration parameters for them:
gsettings list-recursively | grep --ignore-case nautilus
So you have 2 possibilities:
- Switch to Nemo, which has the capabilities you seek out of the box (and more ...)
Clone the source of Nautilus, edit the source code, change Ctrl+PgUp to Ctrl+Tab and build your own version:
cd Documents git clone https://github.com/GNOME/nautilus cd nautilus/src grep --recursive --ignore-case tabs * nano nautilus-window.c #This is where you need to do more work yourself cd .. ./configure make sudo checkinstall
That's as far as I want to go, because I took the easy way and deployed Nemo because I abhor the direction the GNOME developers took as they prefer "simplicity", whereas I like my stuff complex and full of features.
Sorry! ¯\_(ツ)_/¯
- 35,017
This shows up high when googling, but doesn't mention one of the solutions working in 2020, so here you go...
The accels are modifiable through the python-nautilus (nautilus-python in non-Debian-based distros) interface. We install the package and create a plugin:
sudo apt install python-nautilus
mkdir -p ~/.local/share/nautilus-python/extensions
nano ~/.local/share/nautilus-python/extensions/CtrlTab.py
Then insert the following code:
#!/usr/bin/env python
# -*- coding: utf-8 -*-
import gi
gi.require_version('Nautilus', '3.0')
from gi.repository import GObject, Nautilus, Gtk
class CtrlTab(GObject.GObject, Nautilus.LocationWidgetProvider):
def get_widget(self, uri, window):
app = Gtk.Application.get_default()
app.set_accels_for_action("win.tab-previous", ["<shift><control>Tab", "<control>Page_Up"])
app.set_accels_for_action("win.tab-next", ["<control>Tab", "<control>Page_Down"])
Save, exit and make sure nautilus gets shut down with:
nautilus -q
- 41
Old Bug
This is an old bug appearing in many bug reports. This bug report is from 2009.
FireFox and Windows both support Control+Tab for switching tabs. On many laptops Page Up might be hard to reach or poorly labeled. Even on most desktop keyboards Control+Page Up is impossible to perform with the left hand.
For one-handed shortcuts you can use Alt+1 for the first tab, Alt+2 for the second tab, etc.
Gnome's design is for Control+Tab is used for switching panes within windows. For example from the main pane to the left side pane.
Suggested gsettings hack that doesn't seem to work
A "hack" in this bug report illustrates these two gsettings you can view before changing:
$ gsettings get org.gnome.Terminal.Legacy.Keybindings:/org/gnome/terminal/legacy/keybindings/ next-tab
'<Control>Page_Down'
$ gsettings get org.gnome.Terminal.Legacy.Keybindings:/org/gnome/terminal/legacy/keybindings/ prev-tab
'<Control>Page_Up'
Then to change them use:
$ gsettings set org.gnome.Terminal.Legacy.Keybindings:/org/gnome/terminal/legacy/keybindings/next-tab '<Primary>Tab'
$ gsettings set org.gnome.Terminal.Legacy.Keybindings:/org/gnome/terminal/legacy/keybindings/prev-tab '<Primary><Shift>Tab'
This successfully changes behavior switching between gnome-terminal tabs but has no effect in Nautilus or even YAD.
- 105,762
