I have a TP-Link T2U Wi-Fi adapter and I was in struggle to find a working driver for Ubuntu 18.10. All the drivers, original and modified, was for previous version of the kernel but nothing useful for the 4.15 kernel. After a painful morning I found a working link to run the TP-Link T2U on the latest kernel.
Here is the link: Trying to fix the MT7610U chipset driver - GitHub
After following the instructions everything worked! I found the link on TP-LINK Archer T2U v2 - WikiDevi.
If you would install the driver you will need to compile the source. To do this you will need install git and clone the repository in your home directory.
sudo apt install git
cd ~
git clone https://github.com/xtknight/mt7610u-linksys-ae6000-wifi-fixes.git
cd mt7610u-linksys-ae6000-wifi-fixes
You can avoid to write the whole directory just type the first letters, for example, mt7610, and press the Tab key.
sudo apt-get install build-essential linux-headers-$(uname -r)
make clean
make
sudo make install
After these steps the device should work. If you want the driver to work after the updating the kernel I advise to follow the next steps that includes the dkms utility. You will need to work in the directory "mt7610u-linksys-ae6000-wifi-fixes" otherwise the process will not work.
sudo apt-get install dkms
sudo cp -R . /usr/src/mt7610u_sta-1.0
sudo dkms add mt7610u_sta/1.0
sudo dkms build mt7610u_sta/1.0
sudo dkms install mt7610u_sta/1.0
I hope to be useful for the further development of this OS.
