How can I install driver for Realtek 8188CU Wifi USB adapter?
But didn't worked nothing.
Is there a solution for that?
    /var/lib/dkms/rtl8192cu-tjp/1.6/build/os_dep/linux/os_intfs.c:444:7: error: dereferencing pointer to incomplete type
    entry->write_proc = proc_set_rx_signal;
   /var/lib/dkms/rtl8192cu-tjp/1.6/build/os_dep/linux/os_intfs.c:446:8: warning: assignment makes pointer from integer without a cast [enabled by default]
    entry = create_proc_read_entry("ampdu_enable", S_IFREG | S_IRUGO,
  /var/lib/dkms/rtl8192cu-tjp/1.6/build/os_dep/linux/os_intfs.c:452:7: error: dereferencing pointer to incomplete type
   entry->write_proc = proc_set_ampdu_enable;
   /var/lib/dkms/rtl8192cu-tjp/1.6/build/os_dep/linux/os_intfs.c:454:8: warning: assignment makes pointer from integer without a cast [enabled by default]
    entry = create_proc_read_entry("rssi_disp", S_IFREG | S_IRUGO,
 /var/lib/dkms/rtl8192cu-tjp/1.6/build/os_dep/linux/os_intfs.c:460:7: error: dereferencing pointer to incomplete type
    entry->write_proc = proc_set_rssi_disp;
  cc1: some warnings being treated as errors
  make[1]: ** [/var/lib/dkms/rtl8192cu-tjp/1.6/build/os_dep/linux/os_intfs.o] Erro 1
  make: ** [_module_/var/lib/dkms/rtl8192cu-tjp/1.6/build] Erro 2
   make: Saindo do diretório `/usr/src/linux-headers-3.13.0-63-generic'
