I'm new to Ubuntu, very new, and doesn't really know if what I'm doing is correct.
I installed Ubuntu 13.10 5 days ago, my tplink tl-wn723n wifi usb adapter connects to the wifi router but keeps asking for the password, searched google and found out it's a bug, my tplink is version 2 so that means it has rtl8188cus.
so far, what I've tried are:
blacklisting certain modules, I'm not sure if I did it correctly: to /etc/modprobe.d/blacklist.conf I added:
# Blacklist native realtek 8188cus drivers
blacklist rtl8192c
blacklist rtl8192c_common
blacklist rtlwifi
downloaded the driver from realtek, for 8188cus, extracted it, then ran sudo bash install.sh. after restarting, I don't get wifi on my network anymore.
I also tried doing the rtl8192cu-tjp-dkms_1.6_all made by tim, at some point. I was able to install this, but now, when I try to, it won't. It would say:
Dependency is not satisfiable: dkms (>= 1.95)
please help, i may need noob instructions todo this
David Foerster
  • 36,890
  • 56
  • 97
  • 151
user207056
First of all, ensure you have the necessary prerequisites:
sudo apt-get install linux-headers-generic build-essential dkms git
Clone the updated driver with git:
git clone https://github.com/pvaret/rtl8192cu-fixes.git
Set it up as a DKMS module:
sudo dkms add ./rtl8192cu-fixes
Build and install the driver, you may need check the version here (e.g. 1.9 may change):
sudo dkms install 8192cu/1.9
Refresh the module list:
sudo depmod -a
Ensure the native (and broken) kernel driver is blacklisted:
sudo cp ./rtl8192cu-fixes/blacklist-native-rtl8192.conf /etc/modprobe.d/
Let's not take any chances. Instruct Ubuntu to load the new driver when it starts up.
echo 8192cu | sudo tee -a /etc/modules
Reboot.
You're done.
Thanks to P. Varet for this awesome fix.
psiphi75
  • 976
SirCharlo
  • 40,096
